Pinephone Freeze
(02-10-2022, 05:43 PM)kmsgli Wrote: Hey folks, I have been daily driving my pinephone running manjaro phosh since November and overall very usable however every day or two my phone ends up frozen and needs a hard reboot (it never happens when on the charger).
Hi, i have the same problem on pinephone pro on all distro.  The lock screen is black and impossible to unlock, only hard reboot helps.  It may be worth tracking down the problem of the system monitor, but have not yet figured out how due to little experience.
Pinephone Freeze - by kmsgli - 02-10-2022, 05:43 PM
RE: Pinephone Freeze - by edgefull - 02-25-2022, 01:46 AM
RE: Pinephone Freeze - by edgefull - 02-25-2022, 03:48 AM
RE: Pinephone Freeze - by kmsgli - 02-27-2022, 07:43 AM
RE: Pinephone Freeze - by edgefull - 02-27-2022, 07:54 AM
RE: Pinephone Freeze - by kmsgli - 02-27-2022, 03:23 PM
RE: Pinephone Freeze - by edgefull - 02-27-2022, 07:42 PM
RE: Pinephone Freeze - by kmsgli - 03-05-2022, 09:15 AM
RE: Pinephone Freeze - by some_pinephone_user - 11-10-2022, 06:20 AM
RE: Pinephone Freeze - by Westslope - 01-23-2023, 08:51 PM
RE: Pinephone Freeze - by zetabeta - 01-24-2023, 08:07 AM
RE: Pinephone Freeze - by Westslope - 02-04-2023, 08:35 PM
RE: Pinephone Freeze - by Kevin Kofler - 01-24-2023, 07:33 AM
RE: Pinephone Freeze - by Kevin Kofler - 01-24-2023, 09:50 AM
RE: Pinephone Freeze - by zetabeta - 01-24-2023, 01:05 PM
  link for supported pinephone os manjharo et all penguins_rule 3 372 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 523 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,926 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,695 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone craches after each call neithan76 2 1,674 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 30,106 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,168 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,803 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,959 04-07-2022, 06:02 AM
Last Post: danimations
  Pinephone stuck on 'something went wrong' after update gofishus 1 1,634 03-06-2022, 05:48 PM
Last Post: fxc
