When I set SD card as /home, PP can't complete boot
I can mount the SD card with sudo mount -t ext4 /dev/mmcblk0p1 /home and it works. I'm running that way now, as I type this on the PP.  I have all the stuff in the mobian directory there that I expect.
I follow the instructions in https://wiki.mobian-project.org/doku.php...nencrypted to build the fstab entry.
The fstab line I build is modified from the first line of the current fstab:
UUID=5eb7c824-6cba-41ab-80cc-5c3d45012776    /    f2fs    defaults    0    1
to be like this:
UUID=3314869d-66e3-44ad-8dbb-7a7275b6ea64 /home    ext4    defaults    0    2
With that last line in there, the boot somehow either hangs, or delivers a blank screen, or something.
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
RE: When I set SD card as /home, PP can't complete boot - by nelstomlinson - 12-22-2021, 11:30 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,133 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 1,037 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 885 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,394 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 1,003 03-06-2023, 12:06 PM
Last Post: freelectro
  APN settings not working with new operator SIM card user641 1 1,081 03-01-2023, 04:43 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,157 02-13-2023, 02:11 AM
Last Post: sharase
  What does handle SD card automount? mdk 1 1,085 01-29-2023, 03:15 AM
Last Post: mdk
  [solved] Black screen at boot time mdk 0 1,040 01-13-2023, 03:33 AM
Last Post: mdk
