Just purchased a used PBP (with no eMMC!) - any tips for a new user?
(12-05-2021, 07:58 AM)jiyong Wrote: NVMe would be the best option.
Although I have seen reports that only NVMe drives that use limited power (wattage) work properly in the PBP.
And I'm not sure what you have to do exactly to boot directly from NVMe.
That is correct, too much power draw from the nvme drive can cause problems like the PBP not booting up. that's one reason why we started a wiki page to catalog known, working-in-the-pbp nvme drives: https://wiki.pine64.org/wiki/Pinebook_Pr...SSD_drives
to boot from nvme, you just need a uboot (or levinboot) with nvme boot support in it. it can live on emmc, sd, or spi. if kept on emmc or sd, you'll want to avoid installing any OSes to that same drive, or the uboot boot priority may choose to run it instead of the nvme install. here's an older guide someone put together: https://forum.pine64.org/showthread.php?tid=11864
RE: Just purchased a used PBP (with no eMMC!) - any tips for a new user? - by tophneal - 12-07-2021, 08:28 AM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 78,694 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 3,208 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 2,585 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 3,099 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 6,649 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 4,119 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 4,406 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 3,333 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 5,939 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 4,306 09-28-2022, 06:22 PM
