Tutorial: Run Debian off NVMe
Here are steps that worked for me, to get Debian to boot from NVMe on the PineBook Pro.
  1. Install NVMe adapter and NVMe drive
  2. Get the NVME device name --lsblk should list it, the actual device will be something like = /dev/nvme0n1
  3. Install Debian to the NVMe using this: https://github.com/daniel-thompson/pineb...-installer -- Note: The install failed with a hang (flashing amber-green) the first 2 times I tried it, and succeeded the 3rd time.
  4. Install an updated uboot that supports NVMe onto the SPI: https://github.com/pcm720/u-boot-build-s...v2020.07-1. (Note the boot order is microSD, eMMC, then NVMe, so if you want the PBP to boot from NVMe, you need to disable booting from the eMMC)
  5. Boot into manjaro on eMMC
  6. Disable booting from the eMMC (so the PBP will boot from the NVMe): Rename the /boot/extlinux folder on the eMMC e.g. sudo mv /boot/extlinux /boot/extlinux.dontboot (so the PBP will not boot off the eMMC)
  7. Reboot, and it should boot from NVMe
    Note: if you want to go back to booting from eMMC, mount the 1st partition off eMMC--that is eMMC partition that would normally be mounted to /boot on Manjaro) and change the name from extlinux.dontboot (or whatever you used in step 6) back to extlinux and reboot
Actually, no
@localhost pcm-uboot]$ strings u-boot.img |grep _target
boot_targets=mmc1 nvme0 usb0 mmc0 pxe dhcp
(10-18-2020, 08:27 PM)wdt Wrote: > so if you want the PBP to boot from NVMe, you need to disable booting from the eMMC
Actually, no
Hi @wdt would you mind please providing a bit more info--what file, on what media/partition would you edit to change the boot order?
That is parameters that are set before uboot is compiled
strings u-boot.img OR uboot,img will show about 4-5 pages of things inside uboot
Usually, not all that useful
the grep is for boot_targets, which is uboot search order
To change, you will have to compile uboot yourself
(BTW,, mmc1=SD,,,mmc0=emmc)
I have been looking, maybe there is a trick to "chain" extlinux.conf's, so far no
Other than renaming,, ie extlinux.conf ->extlinux.conf.bak,, that works (or rather, doesn't, ie won't find this one)
Just what are you trying to do? Get a selector?
If so, the only one, so far, is samueldr's uboot, needs a patched kernel (until 5.9, patch will be mainline)
It does sort of work, 2-6 boot attempts needed, so can take a few minutes (this with unpatched kernel)
(10-19-2020, 09:25 AM)wdt Wrote: That is parameters that are set before  uboot is compiled
@wdt ok, I understand.  I was looking for a way to change the order without having to re-build and re-install uboot.
Information levinboot tutorial clover 0 7,655 12-20-2020, 09:30 PM
Last Post: clover
  Lid Magnet Moving tutorial (with pictures) PineyMike 1 6,470 11-27-2020, 04:54 PM
  Deepin Desktop Installation (Fedora 32 Workstation) Tutorial Upokupo 2 10,149 11-04-2020, 07:19 PM
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 13,170 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 95,979 06-07-2020, 02:37 AM
Last Post: as400
  Setup power profile from nvme bootscript korneliuszo 2 17,099 02-11-2020, 11:02 AM
Last Post: korneliuszo
  How to fix keymap of ISO keyboard - default Debian desktop hmuller 10 33,506 01-15-2020, 03:34 PM
Last Post: chip ling
