Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)?
Hi all,
Is there a clear instruction how to upgrade an 1st batch Pinebook Pro with original (Debian-Mate) OS on MMC to the new factory Manjaro or 20.06?
I've already tried manjaro 20.02 and 20.06 on SD and there are fine, so I like to update it to MMC to free up the SD slot.
Another option would be to install it on the SSD and boot from MMC to SSD, but I haven't found a real clear up to date instruction yet.
Or can we have a multiboot bootloader on MMC?
Regards Paul
(06-21-2020, 05:51 AM)pljanson Wrote: Hi all,
Regards Paul
That's easy-just download the Manjaro MicroSD to EMMC installer from here: https://osdn.net/projects/manjaro-arm/st....06.img.xz, flash it to a MicroSD card, put it into your Pinebook Pro, and follow the on-screen instructions, which will guide you through installing Manjaro to the EMMC. It's really easy, and I have actually done it multiple times. Hope this helps!
Regards Paul
Hi I tried that one too, I installed it on SD and it only "installs" on SD, not on MMC. And it has the same filename and size as the SD installer. I however seen that previous versions has a special eMMC file (like  Manjaro-ARM-kde-plasma-pbpro-20.04-emmc-installer-20.04.img.xz) which isn't there (yet?) for the 20.06 files.
You can also install 20.04 and do the upgrade with the package manager.
There is no need to keep installing every new version.
(06-22-2020, 04:59 AM)jiyong Wrote: You can also install 20.04 and do the upgrade with the package manager.
I tried that yesterday and (after some hassle) succeeded Smile
But it took some effort:
I had to install the 20.04 emmc version to SD (although 20.04.19 and 20.06 exist for SD only).
https://osdn.net/projects/manjaro-arm/st....04.img.xz
Then it hangs and you need to press ESC to enter the menu (found somewhere in the of forums).
Like at https://forum.pine64.org/showthread.php?tid=9929
The it just installs and works, although outdated.
So I tried to update with the packagemanager but that hangs on a bug in the 20.04 archive,
but that is also a known issue and I found a pacman command to update with overwrite.
pacman -Syyu --overwrite /usr/lib*/p11-kit-trust.so
See also https://www.unusually.pink/blog/pinebook...jaro-linux
Now finally I got an up to date manjaro (I think).
Now Release info:
cat /etc/lsb-release
Regards Paul
  Building PPSSPP with Manjaro AUR LivingLinux 0 4,762 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 24,536 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 6,449 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 12,864 10-24-2020, 06:38 AM
Last Post: pineitup
  Tutorial: Run Debian off NVMe hive 4 12,118 10-19-2020, 10:09 AM
Last Post: hive
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 6,419 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 5,076 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 16,458 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 94,487 07-11-2020, 09:01 PM
Last Post: xmixahlx
  full disk encryption with luks on manjaro xfce limxr 48 111,251 07-09-2020, 07:27 AM
Last Post: JtR
