[split] Change password from external media
(06-19-2020, 10:56 AM)tophneal Wrote:
(06-19-2020, 10:06 AM)James Good Wrote: New (?) question: how or where would I be able to find the file mentioned?  The PBP has Manjaro as the preinstalled operating system and my main computer, a desktop, has Ubuntu 18.04.4 LTS.  What size of SD card might be required?
Thank you,
James Good
I wouldn't use your Ubuntu machine for this. Boot up a live img of Manjaro, on an SD. Identify and mount the emmc root partition, and use chroot to enter the mounted partition. Then you can run 'passwd [user account name here]' in terminal to set a new password for your account. There is no file to find or change.
Only problem with what you suggest; my desktop computer CAN boot and access the Internet, the PBP does NOT fully boot so I am not able to access anything either on the local computer or on the Internet.  What I had suggested was something thai I would be able to do now.  And not having, or knowing where to find, a live img of Manjaro, I am limited to using what is available.
Thank you,
James Good
RE: [split] Change password from external media - by James Good - 06-19-2020, 04:22 PM
  oem password iwm 8 2,474 02-19-2023, 07:35 PM
Last Post: iwm
  Issues with External Display After Recent Update reundo 0 1,399 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,241 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 13,997 08-24-2021, 04:25 PM
Last Post: bkenn
  Graphical login hanging after password entry mhill8 2 3,392 03-29-2021, 08:32 AM
Last Post: jacksonliam341
  External DVD/CD MIchael 22 22,341 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 1,827 02-17-2021, 08:23 AM
Last Post: Arwen
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,775 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  [split] U-Boot with NVMe support, keyboard & display working as400 83 83,496 01-27-2021, 12:48 AM
Last Post: as400
  MAC address change user0258 2 3,535 09-16-2020, 01:12 PM
Last Post: user0258
