Pinetime not charging/switching on anymore
I have a dev version of the PineTime and after not using it for some time it is not switching on anymore. Maybe it is not charging either.
Are there any things I can try before buying another one?
Thank you in advance
If you are 100% sure it is fully connected to the charger (those springs on the back of the case are relatively strong and one can lift the back away from the other if you are using a tape or a weak glue) then the next step would be to check the battery and regulator voltages with a multimeter.
Battery is easy since the pads are pretty obvious (expect ~3.7v), you can check the regulator voltage by testing the GND and 3V3 from the SWD connector (see https://wiki.pine64.org/wiki/PineTime_Devkit_Wiring ).
(09-03-2021, 05:16 AM)danielt Wrote: If you are 100% sure it is fully connected to the charger (those springs on the back of the case are relatively strong and one can lift the back away from the other if you are using a tape or a weak glue) then the next step would be to check the battery and regulator voltages with a multimeter.
Battery looks to be dead, I am measuring only 0.6v from them.
That doesn't sound great. Certainly sounds like something is broken.
Only other interesting experiment I can think of is to see if the battery (or 5v supply) voltage changes when 5v is applied to the charging pads (e.g. does the charger circuit work or has the battery failed) however it can physically tricky since it's only an easy test if you possess four hands.
An easier, but destructive, alternative might be to desolder one of the battery leads and see if the screen can fire up with the battery disconnected. That would prove whether the problem is battery or charger (and if it is the battery then you do, at least, have a battery-less watch to use as a development/test device if you want to).
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,407 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,266 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,428 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,384 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,392 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,602 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,488 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,785 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,599 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 3,004 01-31-2024, 11:57 AM
Last Post: tynstar
