Kernel crash on Manjaro ARM
Hi! I run manjaro ARM on my pinebook pro. After the latest `pamac upgrade`, I've started to get regular lockups. Checking `journalctl` I have this kernel error in there:
https://pastebin.com/dw1T8x1z
Relevant error messsage seems to be 'Unable to handle kernel NULL pointer dereference', and the call stack looks like this
Jul 06 21:24:57 pinebook kernel: Call trace:
Jul 06 21:24:57 pinebook kernel: drm_ioctl+0x280/0x44c [drm]
Jul 06 21:24:57 pinebook kernel: __arm64_sys_ioctl+0xa8/0xec
Jul 06 21:24:57 pinebook kernel: invoke_syscall+0x48/0x114
Jul 06 21:24:57 pinebook kernel: el0_svc_common.constprop.0+0xbc/0xcc
Jul 06 21:24:57 pinebook kernel: do_el0_svc+0x24/0x90
Jul 06 21:24:57 pinebook kernel: el0_svc+0x2c/0x54
Jul 06 21:24:57 pinebook kernel: el0_sync_handler+0x1a4/0x1b0
Jul 06 21:24:57 pinebook kernel: el0_sync+0x198/0x1c0
Jul 06 21:24:57 pinebook kernel: Code: 35000575 a94573fb 17ffff79 f9401a80 (b940e800)
Jul 06 21:24:57 pinebook kernel: ---[ end trace fe4cd6ccb18f59e7 ]---
It seems the kernel is now version 5.13.0-1, I might try downgrading that.
hmm, `downgrade linux` starts downloading x86 version, that's not gonna work.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,700 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,416 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,515 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,210 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,745 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,083 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,420 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,651 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,554 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,440 11-14-2023, 10:57 AM
Last Post: trifleneurotic
