Installing cinnamon on Manjaro PBP [SOLVED]
This is for a user who just got a PBP (loves it Big Grin ) and before has used LinuxMint Cinnamon since forever.
Since he's used to Cinnamon, he wanted that as a DE, and I thought, "Easy. Go to Add/Remove software, find cinnamon-desktop, and install."
Well, that part was easy. But it keeps booting into KDE. I simply cannot find where you tell the system to use cinnamon. There's no option to choose DE at login (that I could see), and no setting that can be changed after it's booted.
There's got to be a way, right?   Huh   Help, please. Confused
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
The commands here worked.
$ sudo pacman -S cinnamon $ sudo pacman -S cinnamon-wallpapers cinnamon-sounds gnome-terminal parcellite                     ##cinnamon-wallpapers and cinnamon-sounds were not available at whichever repo was hit $ sudo pacman -S lightdm lightdm-slick-greeter lightdm-settings $ sudo systemctl enable lightdm.service --force
The only significant difference, as far as I can tell, to a CLI install I tried earlier is that this one had the --force switch on the last command.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,590 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,237 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,358 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,104 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,649 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,002 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,249 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,487 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,327 11-14-2023, 10:57 AM
Last Post: trifleneurotic
