Building custom kernel (5.11.x) for Manjaro?
Question
Just received my PBP and would like to rebuild kernel for Manjaro with some custom settings.
I just cannot find any pointers how I'm able to rebuild recent kernel and from what repo's (including patches)?
(05-07-2021, 11:44 PM)ppafin Wrote: Just received my PBP and would like to rebuild kernel for Manjaro with some custom settings.
I currently have the kernel which came pre-installed on my new PBP:
Linux bp 5.12.2-2-MANJARO-ARM #1 SMP Sat May 8 20:04:09 UTC 2021 aarch64 GNU/Linux
I tried to rebuild the kernel using ABS, as documented here: https://wiki.archlinux.org/title/Kernel/...ild_System and left most of the options unchanged (so that it should use the config of the current kernel. I end up with the following error during build
crypto/aegis128-neon-inner.c: In function ‘crypto_aegis128_init_neon’:
crypto/aegis128-neon-inner.c:150:3: error: incompatible types when initializing type ‘unsigned char’ using type ‘uin
t8x16_t’
 150 |   k ^ vld1q_u8(const0),
crypto/aegis128-neon-inner.c:151:3: error: incompatible types when initializing type ‘unsigned char’ using type ‘uin
t8x16_t’
 151 |   k ^ vld1q_u8(const1),
This seems to be a known bug in gcc (I'm using the 10.2.0 version from core) which is fixed in later version, so now I'm going to install gccjit and try again.
If anyone has any advice or questions I'd be pleased to hear them.
By the way the gcc bug is https://gcc.gnu.org/bugzilla/show_bug.cgi?id=96377 and it seems like it was fixed in 10.3.
Hey, i started to build the kernel from source too, and the cleanest way i found is to use the PKGBUILD provided by the ManjaroARM guys (https://gitlab.manjaro.org/manjaro-arm/p...r/PKGBUILD) and than add what you want in the script. I simply add commands in the build() section
PinebookPro v2.1 4xA53@1704Mhz / 2xA72@2208Mhz / GPU@1125Mhz / CCI-500@1200Mhz
Problem solved, built new kernel for pbp from mege's repository (https://github.com/megous/linux.git):
# Clone mege kernel
git clone https://github.com/megous/linux.git
# Set variables (using buildroot built toolchain)
CWD=`pwd`
OUT=$CWD/builds
mkdir -p $KBUILD_OUTPUT $OUT/pc2
export KBUILD_OUTPUT=$OUT/.tmp/linux-arm64
export PATH="$PATH:~/buildroot/output/host/bin"
export CROSS_COMPILE=aarch64-linux-
export ARCH=arm64
# Checkout orange-pi-x.xx branch
cd linux
git checkout orange-pi-5.13
cd ..
# Use 'pinebook_pro_defconfig' config
make -C linux pinebook_pro_defconfig
# NOTE: Check wifi blob before build
make -j5 -C linux clean
make -j5 -C linux Image dtbs
# Output
ls ~/builds/.tmp/linux-arm64/arch/arm64/boot
dts Image
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,595 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,243 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,361 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,107 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,651 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,002 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,252 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,499 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,469 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,336 11-14-2023, 10:57 AM
Last Post: trifleneurotic
