Python IDEs in Manjaro on the PBP
Linux novice looking to do some python development on my PBP.
On Windows, I primarily use Sublime Text or Spyder.
Unfortunately, Sublime Text does not appear readily available on aarch64 and I have been encountering errors when trying to launch Spyder in Manjaro (I suspect it is an unsupported qt version).
What python IDEs would this community recommend?
I'd start with Geany, it's available in the package manager for most distros that run on the PBP and is a great balance of speed and features. You might want to also check out VSCodium, the open-source build of VSCode.
(06-30-2020, 09:47 PM)qchapter1 Wrote: I'd start with Geany, it's available in the package manager for most distros that run on the PBP and is a great balance of speed and features.  You might want to also check out VSCodium, the open-source build of VSCode.
Thanks for the suggestions!
I like how Geany has a similar UI to Sublime Text (I might play around with it later).
I'll give VSCodium a spin first, as it seems to be a bit more platform agnostic - thanks to the open-source build. I can learn it once and use it both on Linux/Windows!
Update: I was successfully able to install VSCodium via AUR.
Everything went smoothly following the official guide.
I tried to install Codium and have yet to do so successfully.  I tried to install Geany via snap and could not get it installed that way either.  Ultimately I installed Geany via:
sudo pacman -S geany
https://discover.manjaro.org/applications/geany
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,189 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,744 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,421 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,531 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,957 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,179 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,670 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,122 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,908 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,618 11-14-2023, 10:57 AM
Last Post: trifleneurotic
