Will It Be Okay To Order The PineBook Pro US Version For Use In The UK?
Hi
Is it okay to order the US version of the PineBook Pro for use in the UK? The different keyboard layout doesn't bother me, I just wanted to know if there's anything else I should be aware of? For instance maybe voltage issues?
The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
(03-15-2021, 02:27 PM)dsimic Wrote: The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
But it can still charge through USB-C though?
Yes, it can, although there are some issues with the amount of power the PineBook Pro is capable of taking from any of its two power inputs (the barrel jack and the USB Type-C port).  Please, have a look at this thread as well.
My ANSI PBP came with a UK and a US plug. I can't be certain, but I think both of the ones I bought did. So you might get the correct plug anyway. If not, it should be easy to get one.
That's interesting.  My ANSI variant of the PineBook Pro came with an EU plug only.
I thought it was strange. I might have saved the second one just because I hate to throw things like that out, but there's zero chance of me ever needing it.
Quite frankly, one of the very few things I have really no regrets about throwing into garbage is a UK wall plug adapter or a UK wall wart. Big Grin  No offense to anyone, it's just that I absolutely don't need them and they take up a lot of space.
  dead Pinebook - help please RicTor 3 756 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,703 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 7,912 02-09-2026, 12:50 AM
Last Post: Anthona
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 1,133 01-03-2026, 07:09 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 667 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,261 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,215 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 3,971 06-28-2025, 01:25 AM
Last Post: Www
  upgrading u-boot--what version? where to get it? bsammon 14 15,173 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Use SD to install new OS over pinebook debian Rudy558 10 25,616 03-09-2025, 11:17 AM
Last Post: davisthomas
