Will It Be Okay To Order The PineBook Pro US Version For Use In The UK?
Hi
Is it okay to order the US version of the PineBook Pro for use in the UK? The different keyboard layout doesn't bother me, I just wanted to know if there's anything else I should be aware of? For instance maybe voltage issues?
The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
(03-15-2021, 02:27 PM)dsimic Wrote: The only issue you might experience in the UK is being unable to use the DC adapter without a wall plug adapter.  The shipped DC adapter actually supports interchangeable wall plugs, but gets shipped with only one wall plug.
But it can still charge through USB-C though?
Yes, it can, although there are some issues with the amount of power the PineBook Pro is capable of taking from any of its two power inputs (the barrel jack and the USB Type-C port).  Please, have a look at this thread as well.
My ANSI PBP came with a UK and a US plug. I can't be certain, but I think both of the ones I bought did. So you might get the correct plug anyway. If not, it should be easy to get one.
That's interesting.  My ANSI variant of the PineBook Pro came with an EU plug only.
I thought it was strange. I might have saved the second one just because I hate to throw things like that out, but there's zero chance of me ever needing it.
Quite frankly, one of the very few things I have really no regrets about throwing into garbage is a UK wall plug adapter or a UK wall wart. Big Grin  No offense to anyone, it's just that I absolutely don't need them and they take up a lot of space.
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 1 629 11-14-2025, 05:27 AM
Last Post: wangyukunshan
  Pinebook Pro for sale rfm83 0 380 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,863 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,888 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,203 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,748 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,135 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  upgrading u-boot--what version? where to get it? bsammon 14 13,826 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Use SD to install new OS over pinebook debian Rudy558 10 23,827 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,735 02-05-2025, 03:56 AM
Last Post: waylonwesley
