DOA Pinecil?
My Pinecil arrived this morning and it doesn't seem to be working.
When I power it up, the main screen pops up and I can go through the menus, but as soon as I try to turn the heat on, it blinks off and then restarts.
I tried updating the firmware, but got an error message when I tried to flash it:
Invalid DFU suffix signature A valid DFU suffix will be required in a future dfu-util release!!! Error during special command "MASS_ERASE" get_status
DFU-Util exited with error code 74!
Flashing failed.
Any suggestions on how to get it working?
(01-26-2021, 08:30 PM)foobarney Wrote: My Pinecil arrived this morning and it doesn't seem to be working.
Flashing failed.
Please make sure that your power supply is not under power and trigger self protection when pinecil try to heat up.
For DFU error, please visit this thread: https://github.com/Ralim/IronOS/issues/820[url=https://github.com/Ralim/IronOS/issues/820][/url]
Flashing failed.
I checked with multiple power supplies--when I plug in a 12V supply the little numbers on the right of the display ramp up to 12; when I plug in a 60W USB-C PD supply, they ramp up to 20. So I don't think the Pinecil thinks it's undervolted.
And I don't think the power connector is loose, because it works fine in the menus; it only happens when I go to solder.
I tried pulling out and reseating the tip just to confirm that it wasn't the problem--no change.
(01-27-2021, 10:17 PM)foobarney Wrote: I checked with multiple power supplies--when I plug in a 12V supply the little numbers on the right of the display ramp up to 12; when I plug in a 60W USB-C PD supply, they ramp up to 20. So I don't think the Pinecil thinks it's undervolted.
If the unit is tripping off as soon as you attempt to heat the tip this is most likely a poor power supply or a bad tip.
[quote pid='88457' dateline='1611829297']
[/quote]
Ive tried multiple power supplies (both barrels and usb-c), so that seems an unlikely culprit.
Unfortunately, I don't have another tip to test with.
Would there be a log somewhere I could dump?
If it's the tip, how do I go about replacing it? I haven't seen any RMA/support info on Pine's website.
Thank you!
I tried the USB-PD with another cable and it seems to be working.
Not sure why the barrel connector did the same thing, though. I'm looking for another high-enough-power adapter with a 5025 connector to really test it.
Thanks, all...
Just a follow-up...working nicely thru USB-C. I'm not sure whether the problem w the barrel connector is the iron or the power supply...I'll need to get a decent 5025 adapter to try.
  pinecil v2 dosent negotiate power moses 0 1,010 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 789 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,189 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,292 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,184 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,581 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,005 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,943 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,788 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 6,439 05-15-2025, 10:41 AM
Last Post: dreieck
