PinePhone OS & Malfunction
Please, have you any way to install mobian? I'm used to install Debian from ISO CD, for this I use a sofware to make iso DVD and than I boot from that. How can I do this with the phone from USB pen? Is it possible?
Thanks, Regards
(12-12-2020, 02:43 AM)tommaso Wrote: Please, have you any way to install mobian? I'm used to install Debian from ISO CD, for this I use a sofware to make iso DVD and than I boot from that. How can I do this with the phone from USB pen? Is it possible?
Thanks, Regards
https://wiki.pine64.org/index.php/Main_Page
You need to flash a system image to sdcard, or you need to flash jumpdrive to a sdcard and then the internal memory will show up as a storage device on USB.
https://mobian-project.org/
  New PinePhone user issues greenpineuser 8 8,194 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,463 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,939 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,706 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 4,977 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 7,782 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 8,915 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 19,376 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 4,341 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 53,802 07-28-2022, 12:40 PM
Last Post: johaennessen
