networkmanager-l2tp on Manjaro 20.04
Hey good people.
Has anyone managed to get networkmanager-l2tp to establish a connection on Manjaro 20.04 for the Pinebook Pro?  On mine, xl2tpd keeps quitting with a signal 15 as soon as it tries to establish a connection, and frustratingly does not provide any details as to why.  I'm not sure if it supports any sort of verbose logging, and I'm still fuzzy as to where networkmanager-l2tp stashes the configs it passes to strongswan and xl2tpd where I might turn such logging on or at least double-check the config.  The connection establishes fine on Debian using the unofficial installer, as well as other clients I've connected previously, so I know my general setup is fine.  I just can't figure out why Manjaro won't connect.
Anyone have any pitfalls they've encountered getting it working, something I might check for?  I really want to give Manjaro a fair shot if at all possible, but not being able to use my home VPN is a bit of an issue.   Undecided
See the README.md file on how to enable debugging and where it stashes the configs it passes to strongswan, xl2tpd and pppd:
https://github.com/nm-l2tp/NetworkManage.../README.md
Thanks for the info.  That should help me dig into the problem a little deeper.  Although currently I've been able to get Armbian working with both L2TP and LUKS drive encryption, the video performance in web browsers is awful and so I'm still motivated to get this working.  If I happen to turn up anything potentially useful I'll post it here... when I get the chance to circle back and test it.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,919 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,386 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,948 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,316 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,735 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,986 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,303 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,581 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,754 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,400 11-14-2023, 10:57 AM
Last Post: trifleneurotic
