PSA: Transition in progress - don't update !
#41
Hello
I've installed "mobian-pinephone-phosh-20201113.img.gz"
Each day, I make 'apt update && apt dist-upgrade'. It is necessary to reflash ?
The videos can be read with 'mpv' but not with the default application for MP4 and MKV. The default application freeze the phone  : hard reboot required because no SSH connection possible.
I can receive calls even in sleep mode :-)
Now, only two boring things :
  1. I can not close any application, the cross to close it is invisible.
  2. Even if I set a french keybord (AZERTY with the accented letters), I have only a QWERTY keyboard.
For the moment, the first thing is the more problematic.
There is a way to solve something ?
Thank you for the work.
[url=https://images.mobian-project.org/pinephone/mobian-pinephone-phosh-20201113.img.gz][/url]
#42
The new way to close windows in Phosh is swiping them upwards instead of tapping the cross.
#43
A big THANK YOU Smile
#44
(11-17-2020, 03:56 PM)Gribouille Wrote: [*]Even if I set a french keybord (AZERTY with the accented letters), I have only a QWERTY keyboard.
That's a bug in squeekboard, you should select (in Settings) the keyboard labelled "French" (and nothing else, no additional variant indication)
#45
Thank you Smile  Now I have the accents.
#46
Yesterday an 'apt dist-upgrade" was done. The phone was let active all the night with sleep mode active.
This morning it was not possible to hear the phone, after a reboot all is normal.
#47
When I use the USB-3 Dockbar and a monitor, the alone way to move an application to the monitor is to use a mouse.
Why it's not possible to use the fingers ?
  No touch KB after update(forky) biketool 4 2,988 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,552 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 21,128 12-04-2024, 07:01 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 5,008 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 5,197 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 17,565 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 14,643 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 16,444 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 5,745 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 14,866 09-05-2022, 12:10 AM
