cad files for rear case/battery upgrade
I'm looking for the cad file for the rear case so I can 3d print and give the phone a huge battery.
Also, how would I go about adding a new battery? Could I get a polymer battery, but how would I wire in the thermistor and protection and what part would that be? would be better to wire into the Vbus pongo pin?
owo notices your distro.
(11-15-2020, 06:27 AM)dallytaur Wrote: I'm looking for the cad file for the rear case so I can 3d print and give the phone a huge battery.
3D File
https://files.pine64.org/doc/datasheet/p...0Cover.stp
Found here
https://wiki.pine64.org/index.php?title=PinePhone
Which is probably a good place to start for your battery questions. Also xnux.eu is another hardware entry place.
HTH
LF
3D File
Found here
HTH
LF
thanks I've been I just need to find a way of wringing a battery is the temp sensor required for the charger and if it is how do I wire it in. do I geta 100k thermistor and wire it it?
Check the schematics for the power pogo pins, and make some measurements to confirm before connecting anything as some of the documentation was contradictory. Schematics are also linked from the wiki page. I think you'll need a battery and a charger/psu board to go between your battery and the power pins. Use whatever temperature sensor your charger/psu board specifies.
(11-17-2020, 04:40 AM)wibble Wrote: Check the schematics for the power pogo pins, and make some measurements to confirm before connecting anything as some of the documentation was contradictory. Schematics are also linked from the wiki page. I think you'll need a battery and a charger/psu board to go between your battery and the power pins. Use whatever temperature sensor your charger/psu board specifies.
I found the datasheet it looks like I need a 3K NTC wired into ground
I think I misunderstood what you're doing. If you're needing the NTC I guess you're looking to use the normal battery terminals and replace the usual battery entirely, rather than adding a second battery as I thought. You should check out what the charge controller is doing as your battery may have different voltage characteristics to the stock one (max charge voltage, minimum voltage etc.) I'm not familiar with that bit, but Megous' site might be a good starting point:
https://xnux.eu/devices/pine64-pinephone.html
  Does PinePhone support long-term battery health optimization? roseblack 5 5,042 10-06-2025, 09:05 PM
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 3,048 04-17-2025, 04:11 AM
  cpupower-gui profiles and battery life biketool 5 6,478 03-28-2025, 05:38 AM
  Battery life suggestion aular2 2 3,480 08-05-2024, 09:06 PM
Last Post: aular2
  How To Share The External MicroSD Folders and Files On A Network? pinephoneuser22 5 7,139 02-10-2024, 08:47 AM
Last Post: jakfish
  Error while dist upgrade PostmarketOS shellchocolat 0 2,591 03-16-2023, 02:56 AM
Last Post: shellchocolat
  Megi's Kernel and Battery Life biketool 3 5,895 01-09-2023, 11:33 PM
Last Post: Canyonless
  No sound after Mobian upgrade arbocenc 1 3,182 11-28-2022, 11:02 AM
Last Post: arbocenc
  WIRELESS CHARGING ADD-ON CASE Fred Zyphal 4 6,832 08-28-2022, 05:17 PM
Last Post: Fred Zyphal
  PinePhone Pro battery life Barugon 17 29,681 07-29-2022, 09:23 AM
Last Post: prog-amateur
