Battery life suggestion
Since my other account is unable to recieve recovery emails since somebody blocked it i had to create a new account and start over.
So what i wanted to ask or suggest is is it possible for somebody to create 2 versions of an os. What i mean by that is since android and ios do all this stuff that reserves battey life like shutting down processes and other stuff to drastically improve battery life, is there a developer willing to copy that same model to improve battery life but have 2 os versions where 1 has what we have now and the other has the clone of the android ios battery life but for the pine phone?
(07-29-2024, 08:08 AM)aular2 Wrote: Since my other account is unable to recieve recovery emails since somebody blocked it i had to create a new account and start over.
That would be nice if it gets implemented. However, the hardware architecture of the pinephone makes it difficult to do so AFAIK. Have you encountered a computer with Android OS/IOS installed on bare metal?
Waydroid is a solution if you want android in Pinephone. But for battery life, I suggest buying extra samsung batteries or power banks.
i think the problem can be solved to increase battery life. Only way to give it a try. Android/ios on a computer, no but i can still think it will work in reality based on current hardware
  Does PinePhone support long-term battery health optimization? roseblack 5 5,042 10-06-2025, 09:05 PM
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 3,048 04-17-2025, 04:11 AM
  cpupower-gui profiles and battery life biketool 5 6,478 03-28-2025, 05:38 AM
  rough estimate of expected microSD installation life? andrewp907 7 9,742 06-10-2023, 07:55 PM
Lightbulb Suggestion: NFC-F / FeliCa Support for next gen PinePhone or board add-on iamauser 0 2,568 03-11-2023, 10:21 AM
Last Post: iamauser
  Megi's Kernel and Battery Life biketool 3 5,895 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 29,681 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 4,376 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 17,101 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 5,436 03-30-2022, 12:02 AM
Last Post: JohnDoe
