Megi's Kernel and Battery Life
I am an everyday driver pinephone 3-32gb w/mobian user.
The reboots and modem cutouts during the day are survivable, but the battery life is difficult at best.
If I rent a car and the poser or USB port is dead it means only satellite navigation at the end of a trip.  No video or surfing on the train unless there is a USB port or mains jack.  Even listening to an audio book can easily knock me to below 50% after two-three hours and will continue to until the hardware audio acceleration and buffer is improved.  Even 10 minutes checking webmail can easily burn 15%.
Most often the answer is Megi's kernel, but as this is an everyday driver phone I want something at least as stable as I already have.
If Megi's kernel is better why is it not adopted by Mobian or other distros?
What is the downside aside form being outside the normal software upgrades?
Back in the Nokia/Maemo days the testing repos for Maemo5 had the power kernel with all of the extra community tweaks to turbocharge the distro and it included missing hardware optimizations, all just an apt-get install away from a reliable alternate to the Nokia kernel.
To those already running Megi's kernel and other tweaks what is your difference in battery life as well as system performance, what about system reliability?
https://xnux.eu/howtos/build-pinephone-kernel.html
https://github.com/megous/linux/tree/orange-pi-5.16
I haven't tried Megi but I was debating just adding a fat stack of batteries, I wonder if anyone else has thought about this?
Like, a power bank or two attachments in addition to the external keyboard (which is also kind of a power bank)?
(09-11-2022, 01:37 PM)biketool Wrote: ...
take a look at latter part of udev rule, number in a file needs to higher than in default udev file for modem.
# possible file location /lib/udev/rules.d/98-prevent-flipping-frames.rules # for preventing flipping frames bug, could waste battery KERNEL=="1c40000.gpu", SUBSYSTEM=="platform", DRIVER=="lima", ATTR{power/autosuspend_delay_ms}="-1" KERNEL=="1c40000.gpu", SUBSYSTEM=="platform", DRIVER=="lima", ATTR{power/control}="on" KERNEL=="1c40000.gpu", SUBSYSTEM=="devfreq", ATTR{min_freq}="432000000" KERNEL=="1c40000.gpu", SUBSYSTEM=="devfreq", ATTR{max_freq}="432000000" KERNEL=="1c40000.gpu", SUBSYSTEM=="devfreq", ATTR{target_freq}="432000000" # for modem disconnections, !wastes battery! ACTION!="add", GOTO="eg25_end-edit" SUBSYSTEM!="usb", GOTO="eg25_end-edit" DRIVER!="usb", GOTO="eg25_end-edit" ENV{DEVTYPE}!="usb_device", GOTO="eg25_end-edit" # (not) Default attributes values ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/control}="on" ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/autosuspend_delay_ms}="3000" ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/wakeup}="enabled" ATTRS{idVendor}=="2c7c", ATTRS{idProduct}=="0125", ATTR{power/persist}="0" LABEL="eg25_end-edit"
All of the operating systems available right now use megi's kernel or a modified version of megi's kernel already.
  Does PinePhone support long-term battery health optimization? roseblack 5 5,058 10-06-2025, 09:05 PM
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 3,052 04-17-2025, 04:11 AM
  cpupower-gui profiles and battery life biketool 5 6,496 03-28-2025, 05:38 AM
  Battery life suggestion aular2 2 3,485 08-05-2024, 09:06 PM
Last Post: aular2
  Linux Kernel development Uturn 10 10,628 11-09-2023, 08:46 AM
  rough estimate of expected microSD installation life? andrewp907 7 9,747 06-10-2023, 07:55 PM
  Differences bwteeen megi's kernel e sunxi64 user641 2 4,094 03-12-2023, 06:39 PM
  PinePhone Pro battery life Barugon 17 29,728 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 4,380 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 17,106 04-05-2022, 06:11 AM
Last Post: Anna
