eMMC Fails After Suspend
Bug
Most of the time, after the device going to sleep and waking up, everything works fine. But on occasion, when the device wakes up, the eMMC does not, and disk requests hang. For example, if I had a terminal already open and type 'ls' in it, it hangs. As one might expect, the DE also starts falling apart rather quickly.
Does anyone know what the issue here is? Is my eMMC chip bad, do I need a new u-boot firmware, is it a kernel or userspace bug?
(11-07-2020, 02:48 PM)Lodj Wrote: Most of the time, after the device going to sleep and waking up, everything works fine. But on occasion, when the device wakes up, the eMMC does not, and disk requests hang. For example, if I had a terminal already open and type 'ls' in it, it hangs. As one might expect, the DE also starts falling apart rather quickly.
I've had this issue since I bought mine in May. I hvve scoured this forum and the telegram group to no success. If you figure this out please let me know. I'm about to chuck this thing into the trash. The hype behind the pbp in the Linux community is very misleading.
I had an issue similar to this with my PBP I got in May. I installed the BSP Uboot and that fixed my issues. Mine would also not boot up 7 out of 8 times I tried to turn it on.
Also, my PBP does not currently wake up from sleep with the 5.9.x kernel. Either disable sleep or go back to the 5.8 series.
The eMMC's do wear out, people have mentioned that.
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,301 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,497 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,420 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,622 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 13,740 04-01-2023, 02:58 PM
Last Post: TRS-80
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 4,335 03-24-2023, 04:25 PM
Last Post: srs5694
  NVME fails detection our0 1 3,465 01-30-2023, 08:45 AM
Last Post: Tazdevl
  My installation guide starting from messed up eMMC Besouro 0 3,274 12-19-2022, 01:01 PM
Last Post: Besouro
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 6,046 10-31-2022, 10:14 AM
  newer ""emmc-installer" images (manjaro xfce) magistral 1 3,591 10-10-2022, 06:22 AM
Last Post: maxjrh
