Private Internet Access VPN on Pinebook Pro
(10-25-2020, 04:34 PM)bastafari Wrote:
(10-25-2020, 10:14 AM)silverine Wrote: Bastafari,
I am looking to set up my expressvpn on my new pinebook pro running the pre loaded manjaro os.  I'd be very interested in how you achieved it, but the link you provided doesn't seem to be working for me.  Could you share the process in some other way?  Many thanks in advance!
Click the hyper link in the post by me before you. It takes you to a guide I made. It may or may not apply to you but give a shot.
Sent from my OnePlus 7 Pro using Tapatalk
I'm still having no luck with that link (404 page not found error), could you try re-posting it maybe?  I'd be very grateful.
Nevermind, the issue must have been on my end. I tried it on another computer and the link worked. I was able to get the VPN set up. Thanks!
(10-27-2020, 10:53 AM)silverine Wrote: Nevermind, the issue must have been on my end. I tried it on another computer and the link worked. I was able to get the VPN set up. Thanks!
Awesome.
(10-23-2020, 11:16 AM)11Eleven Wrote: Greetings,
Do any of you use VPN's on your pinebook pro?  I tried installing PrivateInternetAccess on mine, but it doesn't want to run.  I was wondering if anybody here had any success with it, or could point me to a suitable alternative.  Also, how would I go about uninstalling it, I'm still presently a noob...
Thanks!
This is for Manjaro OS
You can configure PIA VPN through System settings GUI > Click connections under Network > Click + (add new connection) > select OPENVPN > in VPN (openvpn) tab enter your gateway i.e.
"us-atlanta.privacy.network" , change connection type to password, select your CA Certificate (browse for location of your ca.rsa.2048 cert. Click on advanced > General tab  check box use custom gateway port enter 1198 check box use LZO compression (change to adaptive) > Click security tab change cipher to AES-128-CBC change HMAC Authentication to SHA-1.
Connect to your network then connect to the VPN (picture of a shield) from the toolbar.
Config files download OPENVPN CONFIGURATION FILES (DEFAULT)
https://www.privateinternetaccess.com/he...ovpn-files
  Updated Pinebook Pro? tantamount 2 2,269 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,019 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,744 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,315 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,756 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 10,615 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,928 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,774 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,176 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 29,768 03-09-2025, 11:17 AM
Last Post: davisthomas
