Remove activity manager bar on right side of screen - plasma kde
There is a black transparent bar on the side of the screen that I cannot figure out how to close. It is transparent and is related to the activity manager. I do not want this to stay open since I can't work with this over top of stuff.
How can I close this? The icons on it have no affect on anything.
PS - I can I  use the highlighter in Okular? I wanted to mark the area in question of my image but could not figure out how. The highlighter was added to the annotation tools.
Mine has an X (exit icon) across the top, weird, it's like there is no border/decoration on that window.
If you right click on your bottom panel and choose edit panel you may be able to toggle Activities window's visibility on the small, screen edge menu with the "Activities" option.
Another option is to switch themes and choose to accept the settings of the new theme.
Cheers!
Edit:
The 'pine+tab' keystroke launches that window and I have to click on the window and press the 'esc' key to close it.
I removed it, so I know that it can be done. But sadly I can't for the life of me recall how to do it.
Hmm went away with reboot. Not sure that the issue is solved but I'll mark it as such anyway.
  Another one boots to black screen Sb2024 7 7,602 11-06-2024, 11:27 PM
Last Post: Sb2024
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 2,475 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 11,893 07-27-2023, 07:49 AM
Last Post: dstallmo
  Manjaro Plasma blinking cursor jcun4128 4 5,992 05-08-2023, 11:17 AM
Last Post: korreckj328
  PBP blank screen after updating Manjaro Franko 6 8,362 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 5,783 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 5,761 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 6,634 05-09-2022, 05:53 AM
Last Post: gerstavros
Question linuxmint / webapp-manager popinski 2 5,037 10-10-2021, 09:28 AM
Last Post: popinski
  Putting my screen on TV S265 6 10,382 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
