Pinebook Pro Won't Accept Charge
Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Thanks in advance for your ideas.
I see that usbC cables are starting to show up in dollar stores,,
not at all ideal for charging, but only a dollar experiment.
Do try it both ways,, ie "C" end flipped,,,, if it works, get a better one
You don't want to spend much, so I won't recommend anything else
(and don't be in a rush, give it a hour, sometimes a dead battery takes a while)
Thanks, wdt, for your reply.  I'm a total noob.  I'll look up USB C cables online just to see what you're talking about.  How does the cable hook up to the PBP?  Does it backfeed into the USB C port then?  Also, what did you mean about try it both ways?  I totally agree this is worth trying.  Much appreciated!
I bought several usb-c cables at the dollar store (one us dollar each) and they all worked fine. I also bought one at the corner gas station for $4.99 which also works fine. With usb-c it's the same as charging a phone.
Cheers!
Online will usually be a bit more money, look for the word charging, so maybe
the wires are a bit thicker,, a standard cable, "C" at one end, "A" at the other
The C end can be plugged in 2 different ways, label up or label down
Sometimes it makes a difference, sometimes not. If it is working, the red led will light
You will have to find (or buy) your most powerful charger, 2.4A is usual maximum
Obviously, for a test, OR overnight, you can use one with less amperage, try for 1A minimum
A pc, the usb3 port supplies 900 mA, usb2 gives 500mA
BTW, the pbp usbC port is NOT smart, so don't need to get fancy cable or PD/QC charger
Do try to get a cable that is thick, there are 10 wires in it after all
(10-14-2020, 09:17 PM)rempfer Wrote: Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Before sending it back I'd try opening it up and unplugging the battery, leaving it 30 seconds then plugging it back in. My pinebook stopped charging a while after receipt, any time I plugged in a charger it got stuck in a loop of trying to charge then giving up and this solved it.
The USB-C cable did start charging the PBP and then, after that experiment, the AC power supply resumed charging as well.
Thank you everyone!
  Video Editing Is Possible On The PineBook Pro! ImmyChan 13 17,594 Yesterday, 11:15 AM
Last Post: NorrisFByrd
  Updated Pinebook Pro? tantamount 2 2,699 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,481 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 2,001 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,682 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,175 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,143 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,213 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,103 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,438 06-28-2025, 01:25 AM
Last Post: Www
