RockPro64 has bad Memory (Software sogfaults and kernel panics)
I just purchased a rockpro64, and I am having some very odd issues with it:
- I attempted to install the Debian official image twice, and I caused it to kernel panic with the official image.
- I also attempted to use Armbian, and when I tried to update it, I got a segmentation fault on dpkg.
I have looked around and I have not seen anyone complain about these issues.
EDIT:
This is caused bybad memory. I ran as root on Armbian minimal install:
#memtester 3400M 1
It is on Rockpro64 V2.1 2018-07-02, 4GB variant, date code 4719
Pine64 has get to RMA my device despite me using support and contacting sales over a week ago.
UPDATE 16 Oct:
I hate to say, I have not heard anything useful since I opened up this issue on 4 Oct. I filed a Paypal dispute in the hopes that will get them to respond. This is frankly beyond disappointing. I have been very happy with the Pinephone, and that was the reason I have the RockPro a chance over the RaspPi. This whole ordeal sours my interest in buying anything from Pine again.
I didn't run in to that problem when I installed Debian on a RockPro64.
Could it be related to the firmware accessing memory behind the kernel's back?
https://forum.pine64.org/showthread.php?...9#pid55839
https://wiki.pine64.org/index.php/ROCKPr...sed_memory
https://github.com/ayufan-rock64/linux-b...-578410380
Could it be a problem in the Debian kernel version you're using?
(10-04-2020, 03:33 PM)foresto Wrote: I didn't run in to that problem when I installed Debian on a RockPro64.
I was using the offical debian image and I got my Rockpro64 a week ago....it had 5.8 being installed on it.
Well I figured out why. I ran a memory tester on my chip and there are hard errors on my DDR. I will need to exchange it.
(10-07-2020, 09:52 AM)kop316 Wrote: Well I figured out why. I ran a memory tester on my chip and there are hard errors on my DDR. I will need to exchange it.
Hi kop316,
Could you please detail how you tested the memory of your RockPro?
I am also seeing seg faults that always occur at some point regardless of the used image or SD card.
I tried to run the memtester on my board with fresh image and sure enough there seem to be memory issues in the part of memory it tested.
Resuts: https://pastebin.pl/view/00e8b2d7
Hardware I am using:
Rockpro64 V2.1 2018-07-02, 4GB variant, date code 52 19
running of SD card, tall heatsink installed, powered by Pine 5A power supply
For OS image I used ayufan's buster-minimal-rockpro64-0.10.12-1184-arm64 image.
I believe this one uses recent enough u-boot that does not use the binary blob in RAM.
Command used:
sudo memtester 3G 1
I tried the same on other SBC's I have with no errors so there is definitely something going on with this RockPRO board.
(10-12-2020, 07:38 AM)richese Wrote: I tried to run the memtester on my board with fresh image and sure enough there seem to be memory issues in the part of memory it tested.
Command used:
sudo memtester 3G 1
Sorry I just saw this. I did the same thing you did. I got a minimal Armbian image and run as root:
memtester 3400M 1
And I got DDR Errors. My RockPro64
I'm also experiencing the same issue. ROCKPro64_v2.1, 2018-07-02, 4GB variant, date code 5219, powered by a known good 12V 5A power supply.
Running Armbian Focal or Buster, any time I go to use apt update I get a segmentation fault. I've been unable to run memtester as of yet as I need to find an image with it preinstalled as I can't download anything using apt.
I've got 2 other RockPro64s of the same revision, one with date code 4719 and one with date code 5119. I'll be testing those right now and reporting back.
I cracked open the two other boards and ran memtest on them with no errors reported. I then transplanted that eMMC module onto the date code 5219 board and ran the test again. I was presented with a slew of errors. It's evident that, that ROCKPro64 (v2.1, 2018-07-02 5219) is also defective and will warrant an RMA.
(11-19-2020, 12:36 AM)wildering Wrote: I cracked open the two other boards and ran memtest on them with no errors reported. I then transplanted that eMMC module onto the date code 5219 board and ran the test again. I was presented with a slew of errors. It's evident that, that ROCKPro64 (v2.1, 2018-07-02 5219) is also defective and will warrant an RMA.
I ran memtest with Debian an it seems ok. (v2.1, 2018-07-02). What is noticeable is the high temperature reached (70°C) in spite of a heatsink. Then I put it over a fan and it dropped below 50°C after 9 min
I don't know if it is a good practice (and a good idea) but I cut the conductive pad in order to be able to double the layer on the DDR chip to make the contact with the heatsink. Otherwise it probably does not
  TPM module for rockpro64 misha64 0 2,558 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 8,897 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 2,788 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 37,708 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 2,389 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 4,072 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 11,940 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 2,780 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 10,398 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 4,401 05-27-2022, 06:51 PM
Last Post: justwantin
