TPM module for rockpro64
Hi guys,
Is there any compatible tpm module with rockpro64?
found these for raspberry pi:
https://www.voelkner.de/products/1304508...-1St..html
https://www.berrybase.ch/letstrust-tpm-k...spberry-pi
https://buyzero.de/collections/andere-pl...orm-module
based on Infineon Optiga™ SLB 9672 or 9670 TPM 2.0
GPIO pinout between raspberry and rockpro64 is similar but not identical.
So no idea if they are compatible.
Any suggestion would be appreciated!
  Powering two disks from RockPro64 some_pinephone_user 3 6,715 02-24-2026, 04:43 PM
Last Post: evilbunny
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,180 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 4,667 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,535 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 4,122 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,857 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 17,484 11-08-2022, 03:40 AM
Last Post: ajtravis
  U.FL plug on the Wifi/BT module? domih 8 21,317 10-17-2022, 04:43 AM
Last Post: callegar
  RockPro64 not booting up mvicha@gmail.com 0 4,774 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  Pine Wifi Module williamdieter 2 8,120 07-20-2022, 03:31 AM
Last Post: imianz
