Powering two disks from RockPro64
Hello all. I'm thinking about following option:
connect one 2.5" HDD to a USB3.0 port and second HDD to a USB-C port. Can be both powered on simultaneoulsy only from USB?
If I transfer data from one disk to another will the data transfer be too slow because both disk are on the same USB3 controller?
What if I connect the second disk to a USB2 port?
Only one disk will be working 24/7. The other one will only be turned on for weekly backups.
The USB ports don't have enough power for that unless the drives are externally powered
(02-19-2026, 06:57 PM)evilbunny Wrote: The USB ports don't have enough power for that unless the drives are externally powered
That is what I suspected, thank you. Right now one drive hangs on USB3 port without external power, but I suspect that the whole power delivery is divided between all USB ports, and that is why two drives are impossible without external power right?
(02-19-2026, 09:31 PM)some_pinephone_user Wrote: and that is why two drives are impossible without external power right?
Sorry for the belated reply, missed it.
The way I get round such limitations is by using a powered external USB hub.
  TPM module for rockpro64 misha64 0 3,824 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 14,697 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 4,537 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 49,653 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 4,000 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,674 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 17,118 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 4,655 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 15,326 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 7,003 05-27-2022, 06:51 PM
Last Post: justwantin
