Redshift on Manjaro
Since I use my Pinebook Pro regularly at night, I'd really like a blue light filter. Sadly, I can't get Redshift to work:
$ redshift -O 2700
Using method `randr'.
I did some research and found this issue, suggesting to use the experimental OpenGL driver. So I installed mesa-git (which replaced the mesa package). That didn't work, presumably because that issue was for the RPi.
Also, I tried enabling OpenGL ES 3.0 support as documented on the wiki, which didn't work either.
So, my question is: How do I get redshift (or another blue light filter) to work on the Pinebook Pro with X.org?
I'm having the same issue with my Pinebook Pro running Fedora 32.
But I'd use Gnome's built-in night mode. (which in my case doesn't work)
I'll try testing this on different distros, maybe it will work with the legacy 4.4 kernel....
My understanding is that Redshift (or built-in Night Color mode) doesn't work yet on the mainline kernel. See also earlier thread: https://forum.pine64.org/showthread.php?tid=10189
My current solution for this is to boot from the BSP kernel, as described here: https://forum.pine64.org/showthread.php?tid=9253
This is obviously far from ideal, but it's the only workaround I've found so far for enabling Redshift under Manjaro on the Pinebook Pro. If anyone else finds a better solution I'd love to know Smile
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,386 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,990 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,690 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 3,622 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,062 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,249 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,885 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,345 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,010 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 4,742 11-14-2023, 10:57 AM
Last Post: trifleneurotic
