XMonad on Manjaro: is anyone having success?
Hi. I'm using Manjaro on PineBook Pro and I'm trying to install XMonad.
There is no official package for this WM,  and packages from aur cannot be built (Haskell infrastructure for aarch64 in Manjaro seems broken at all).
I installed GHC and Cabal from Nix repository. I even had successfully built XMonad once, but it failed to recompile itself after an update.
I can now build XMonad binary using GHC from Nix, but it won't start because of different versions of glibc in the system and in the nix environment.
Have anyone a success in running XMonad in Arch? If so, what toolchain you used?
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,701 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,418 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,515 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,210 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,745 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,084 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,420 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,652 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,554 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,451 11-14-2023, 10:57 AM
Last Post: trifleneurotic
