Manjaro and Arch repository with privacy oriented software
#31
I see that ferdi is depreciated from the repo Sad I moved away from hamsket on x86 as we discussed on manjaro thread and I started using ferdi now and I am loving its fluid UI and the layout which also have multiple workspaces and dark mode.
While on Pinebook Pro I am still stuck with Hamsket which is working fine but I was happy to see ferdi on the op but it is not there anymore Sad
Keep up the good work.
Manjaro ARM Team.
Yeah, I could not get it to compile for some pretty much un-debuggable npm-electron-mystery-error a while back, so I dropped it for the sake of having hamsket instead.
Considering that there's at least one interested person in having it back (ie. you :D), I'll take a look at it again soon – maybe the mysterious issue has mysteriously disappeared in the meantime ^^
/edit
btw: multiple updates (caidao, librewolf, jitsi …) are almost ready – working on it :)
@spikerguy: good news, sort of. I've just added ferdi-git to the repo again. Seems to work mostly as it should, except for what seems to be an upstream issue that's been open for a while now (and supposedly fixed, but not really… well, it's somewhat inconclusive); some services don't work due to a wrong / outdated user agent.
At least for WhatsApp there's a workaround, though: https://github.com/getferdi/ferdi/issues...-660928738 (settings=>services=>whatsapp=>open user.js=> edit your index.js in your local recipes folder).
So no promises that everything's awesome – but maybe it's sufficiently okayish, for now ;)
Repo updated.
New versions:
1. Caidao - ungoogled chromium (caidao-84.0.4147.105-1-aarch64)
2. Bitwarden (bitwarden-1.20.0-1-aarch64)
3. LibreWolf (librewolf-79.0.1-aarch64)
4. Jitsi Meet Desktop (jitsi-meet-desktop-2.3.1-1-aarch64)
And Ferdi is back Smile
Bitwarden 1.20.1 as been added to the official Manjaro ARM Stable repository: https://forum.manjaro.org/t/arm-stable-u...ernels/118
(08-17-2020, 11:01 AM)JasonG-FR Wrote: Bitwarden 1.20.1 as been added to the official Manjaro ARM Stable repository: https://forum.manjaro.org/t/arm-stable-u...ernels/118
Yep, good stuff – less work for me ;)
=> will be removed from this repo with the next update.
Hi, I installed ferdi-git but am facing the following issue:
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/dri)
failed to load swrast driver
Starting local server on port 45569
Knex: run
$ npm install sqlite3 --save
Error: Cannot find module '/usr/lib/ferdi/app.asar/node_modules/sqlite3/lib/binding/electron-v9.2-linux-arm64/node_sqlite3.node'
Require stack:
- /usr/lib/ferdi/app.asar/node_modules/sqlite3/lib/sqlite3.js
- /usr/lib/ferdi/app.asar/node_modules/knex/lib/dialects/sqlite3/index.js
- /usr/lib/ferdi/app.asar/node_modules/knex/lib/index.js
- /usr/lib/ferdi/app.asar/node_modules/knex/knex.js
- /usr/lib/ferdi/app.asar/node_modules/@adonisjs/lucid/src/Database/index.js
- /usr/lib/ferdi/app.asar/node_modules/@adonisjs/lucid/src/Database/Manager.js
- /usr/lib/ferdi/app.asar/node_modules/@adonisjs/lucid/providers/LucidProvider.js
- /usr/lib/ferdi/app.asar/node_modules/require-stack/src/index.js
- /usr/lib/ferdi/app.asar/node_modules/require-stack/index.js
- /usr/lib/ferdi/app.asar/node_modules/@adonisjs/fold/src/Ioc/index.js
- /usr/lib/ferdi/app.asar/node_modules/@adonisjs/fold/index.js
- /usr/lib/ferdi/app.asar/internal-server/start.js
- /usr/lib/ferdi/app.asar/electron/ipc-api/localServer.js
- /usr/lib/ferdi/app.asar/electron/ipc-api/index.js
- /usr/lib/ferdi/app.asar/index.js
- /usr/lib/electron/resources/default_app.asar/main.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:797:17)
    at Function.o._resolveFilename (electron/js2c/browser_init.js:281:679)
    at Module._load (internal/modules/cjs/loader.js:690:27)
    at Function.Module._load (electron/js2c/asar.js:769:28)
    at Module.require (internal/modules/cjs/loader.js:852:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.<anonymous> (/usr/lib/ferdi/app.asar/node_modules/sqlite3/lib/sqlite3.js:4:15)
    at Module._compile (internal/modules/cjs/loader.js:967:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1004:10)
    at Module.load (internal/modules/cjs/loader.js:815:32)
    at Module._load (internal/modules/cjs/loader.js:727:14)
    at Client_SQLite3._driver (/usr/lib/ferdi/app.asar/node_modules/knex/lib/dialects/sqlite3/index.js:57:12)
    at Client_SQLite3.initializeDriver (/usr/lib/ferdi/app.asar/node_modules/knex/lib/client.js:250:26)
info: serving app on http://127.0.0.1:45569
warning:
  WARNING: Adonis has detected an unhandled promise rejection, which may
  cause undesired behavior in production.
  To stop this warning, use catch() on promises or wrap await
  calls inside try/catch.
TypeError: Cannot read property 'Database' of undefined
    at /usr/lib/ferdi/app.asar/node_modules/knex/lib/dialects/sqlite3/index.js:84:33
    at Promise._execute (/usr/lib/ferdi/app.asar/node_modules/bluebird/js/release/debuggability.js:384:9)
    at Promise._resolveFromExecutor (/usr/lib/ferdi/app.asar/node_modules/bluebird/js/release/promise.js:518:18)
    at new Promise (/usr/lib/ferdi/app.asar/node_modules/bluebird/js/release/promise.js:103:10)
    at Client_SQLite3.acquireRawConnection (/usr/lib/ferdi/app.asar/node_modules/knex/lib/dialects/sqlite3/index.js:83:12)
    at create (/usr/lib/ferdi/app.asar/node_modules/knex/lib/client.js:280:23)
    at /usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:315:34
    at Object.tryPromise (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/utils.js:53:24)
    at /usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:315:17
    at new Promise (<anonymous>)
    at callbackOrPromise (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:306:12)
    at Pool._create (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:236:9)
    at Pool._doCreate (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:208:36)
    at Pool._tryAcquireOrCreate (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:159:18)
    at Pool.acquire (/usr/lib/ferdi/app.asar/node_modules/tarn/lib/Pool.js:85:14)
    at /usr/lib/ferdi/app.asar/node_modules/knex/lib/client.js:335:26
I can reproduce this. Might require a rebuild, because the Electron package for Manjaro was recently updated.
I'll report back.
@Labo
Should be fixed – couldn't tell you earlier because, well, the board was somewhat offline ;)
(08-23-2020, 01:44 PM)llsf Wrote: @Labo
Should be fixed – couldn't tell you earlier because, well, the board was somewhat offline Wink
Thanks Smile It works now for me too.
I ended up testing and loving Hamsket so I'll stick with it, but it's always nice to have the choice!
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 1,095 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 1,425 02-19-2025, 12:49 PM
Last Post: zkajdan
  By the way, yay arch... KC9UDX 4 2,670 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 1,446 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 3,198 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 1,463 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,447 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 5,088 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 1,429 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 2,554 11-14-2023, 10:57 AM
Last Post: trifleneurotic
