Manjaro and Arch repository with privacy oriented software
#21
It certainly looks nice – especially considering that it's possible to self-host the server portions of it as well, that's always a plus.
So while there's (luckily) not much needed to get it to compile (which makes it easy for everyone to compile it from the AUR), it probably wouldn't hurt to add it to the repo, for convenience's sake. Will be done with the next update :)
Repo updated:
New versions:
1. Signal Desktop (signal-desktop-1.34.2-1-aarch64)
2. Mesa (mesa-20.1.1-1-aarch64)
Deletions:
1. Wire Desktop - got removed as that's now provided via the Manjaro repos.
Additions:
1. Standard Notes Desktop (standardnotes-desktop-3.4.1-2-aarch64).
2. Standard Notes Desktop Git (standardnotes-desktop-git-3.4.1.r17.g9d9132a-1-aarch64).
Repo updated:
New versions:
1. Ungoogled Chromium - Caidao (caidao-83.0.4103.116-1-aarch64)
Repo updated:
New versions:
1. LibreWolf (librewolf-78.0.1-1-aarch64)
2. Bitwarden (bitwarden-1.19.0-1-aarch64)
Repo updated:
New versions:
1. LibreWolf (librewolf-78.0.2-1-aarch64)
2. Bitwarden (hamsket-nightly-bin-0.6.0-12-aarch64)
Wow, I just tried Hamsket. That thing works really well.
I got
- Teams
- Threema
- Riot
- Outlook 365
working without problems. Skype made some trouble with the login, but this is probably not Haskets fault.
Thanks for making this available on the PBP
Star
Anybody having trouble with Signal from the Privacyshark repo on the PBP recently? I upgraded to Manjaro 20.07 last night and now I'm getting this when I run signal-desktop:
Unhandled Error
Error: Cannot find module '/usr/lib/signal-desktop/app.asar/node_modules/@journeyapps/sqlcipher/lib/binding/electron-v9.1-linux-arm64/node_sqlite3.node'
Require stack:
- /usr/lib/signal-desktop/app.asar/node_modules/@journeyapps/sqlcipher/lib/sqlite3.js
- /usr/lib/signal-desktop/app.asar/ts/sql/Server.js
- /usr/lib/signal-desktop/app.asar/main.js
- /usr/lib/electron/resources/default_app.asar/main.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:797:17)
    at Function.o._resolveFilename (electron/js2c/browser_init.js:281:679)
    at Module._load (internal/modules/cjs/loader.js:690:27)
    at Function.Module._load (electron/js2c/asar.js:769:28)
    at Module.require (internal/modules/cjs/loader.js:852:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.<anonymous> (/usr/lib/signal-desktop/app.asar/node_modules/@journeyapps/sqlcipher/lib/sqlite3.js:4:15)
    at Module._compile (internal/modules/cjs/loader.js:967:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1004:10)
    at Module.load (internal/modules/cjs/loader.js:815:32)
Tried reinstalling and everything. If anybody more savvy than myself knows what to do about the above, I'd be forever grateful for your help.
(07-16-2020, 03:17 PM)TheBackburner Wrote: Anybody having trouble with Signal from the Privacyshark repo on the PBP recently? I upgraded to Manjaro 20.07 last night and now I'm getting this when I run signal-desktop:
Unhandled Error
Require stack:
What version of Signal are you running ?
Repo was just updated with a new version of Signal and Caidao.
Unhandled Error
Require stack:
Just updated and it works again. All better. Thanks!
Repo updated.
New versions:
1. Caidao - ungoogled chromium (caidao-84.0.4147.89-1-aarch64)
2. Signal Desktop (signal-desktop-1.34.4-1-aarch64)
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,450 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,068 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,186 02-19-2025, 12:49 PM
Last Post: zkajdan
  By the way, yay arch... KC9UDX 4 5,893 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 4,036 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,534 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,898 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,140 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,316 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,400 12-07-2023, 03:11 PM
