U-Boot with direct NVMe boot support for eMMC/SPI Flash
#81
(07-07-2020, 09:52 AM)mamboman777 Wrote: Well, I got lots of errors on the build.sh.  I think I may be missing dependencies?
fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). make: *** No rule to make target 'realclean'.  Stop. make: *** No rule to make target 'bl31'.  Stop. cp: cannot stat 'build/rk3399/release/bl31/bl31.elf': No such file or directory make: *** No rule to make target 'realclean'.  Stop. fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). make: *** No rule to make target 'mrproper'.  Stop. cp: cannot stat '../build/bl31.elf': No such file or directory make: *** No rule to make target 'pinebook-pro-rk3399_defconfig'.  Stop. make: *** No targets specified and no makefile found.  Stop. /home/joshua/Desktop/u-boot-build-scripts-master/build.sh: line 37: tools/mkimage: No such file or directory dd: failed to open 'idbloader-spi.img': No such file or directory cat: u-boot.itb: No such file or directory cp: cannot stat 'idbloader-spi.img': No such file or directory cp: cannot stat 'idbloader.img': No such file or directory cp: cannot stat 'u-boot.itb': No such file or directory make: *** No rule to make target 'mrproper'.  Stop.
Did you install aarch64-linux-gnu-gcc and use git clone --recursive?
Thanks and sorry.  Did I mention I'm an (below) average Joe? :-)
Well, I appear to be soft bricked.  I downloaded, extracted, ran the build file and moved to a usb.  I plugged the usb into my PBP, copied the files over, then navigated to the folder with spiflash.bin in it and ran "sudo dd if=spiflash.bin of=/dev/mtd0" which appeared to run successfully.  I then clicked reboot.  The machine will not respond now.  I'm not getting any sort of light when I press the power button.  The charge light on the side is the only light I'm getting.  What can I do next to troubleshoot this?  I've tried pressing the reset button.
(07-07-2020, 02:12 PM)mamboman777 Wrote: Well, I appear to be soft bricked.  I downloaded, extracted, rand the build file and moved to a usb.  I plugged the usb into my PBP, copied the files over, then navigated to the folder with spiflash.bin in it and ran "sudo dd if=spiflash.bin of=/dev/mtd0" which appeared to run successfully.  I then clicked reboot.  The machine will not respond now.  I'm not getting any sort of light when I press the power button.  The charge light on the side is the only light I'm getting.  What can I do next to troubleshoot this?  I've tried pressing the reset button.
Go to the bottom of this wiki page and follow those instructions to zero out the SPI: https://wiki.pine64.org/index.php/Pinebook_Pro_SPI
It may also be worth retrying using the instructions for writing to SPI that are given on that wiki page.
Thank you for your help.  I currently cannot get rkdeveloptool to install on my Manjaro x86 machine.  Below is the code.  I've tried directly in the terminal and through the package manager using the AUR.  It looks like --disable-werror is creating problems.  Any ideas here?
Preparing... Cloning rkdeveloptool build files... Checking rkdeveloptool dependencies... Resolving dependencies... Checking inter-conflicts... Building rkdeveloptool... ==> Making package: rkdeveloptool 62-1 (Tue 07 Jul 2020 03:45:35 PM CDT) ==> Checking runtime dependencies... ==> Checking buildtime dependencies... ==> Retrieving sources...   -> Updating rkdeveloptool git repo... Fetching origin ==> Validating source files with sha256sums...     rkdeveloptool ... Skipped ==> Removing existing $srcdir/ directory... ==> Extracting sources...   -> Creating working copy of rkdeveloptool git repo... Cloning into 'rkdeveloptool'... done. ==> Starting pkgver()... ==> Removing existing $pkgdir/ directory... ==> Starting build()... configure.ac:12: installing 'cfg/compile' configure.ac:19: installing 'cfg/config.guess' configure.ac:19: installing 'cfg/config.sub' configure.ac:7: installing 'cfg/install-sh' configure.ac:7: installing 'cfg/missing' Makefile.am: installing 'cfg/depcomp' configure: WARNING: unrecognized options: --disable-werror checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking whether make supports the include directive... yes (GNU style) checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking whether gcc understands -c and -o together... yes checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking whether make sets $(MAKE)... (cached) yes checking whether ln -s works... yes checking build system type... x86_64-pc-linux-gnu checking host system type... x86_64-pc-linux-gnu checking for library containing iconv... none required checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for LIBUSB1... yes checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating Makefile config.status: creating cfg/Makefile config.status: creating cfg/config.h config.status: executing depfiles commands configure: WARNING: unrecognized options: --disable-werror make[1]: Entering directory '/var/tmp/pamac-build-joshua/rkdeveloptool/src/rkdeveloptool' g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT crc.o -MD -MP -MF .deps/crc.Tpo -c -o crc.o crc.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKBoot.o -MD -MP -MF .deps/RKBoot.Tpo -c -o RKBoot.o RKBoot.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKComm.o -MD -MP -MF .deps/RKComm.Tpo -c -o RKComm.o RKComm.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKDevice.o -MD -MP -MF .deps/RKDevice.Tpo -c -o RKDevice.o RKDevice.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKImage.o -MD -MP -MF .deps/RKImage.Tpo -c -o RKImage.o RKImage.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKLog.o -MD -MP -MF .deps/RKLog.Tpo -c -o RKLog.o RKLog.cpp g++ -DHAVE_CONFIG_H -I. -I./cfg  -Wall -Werror -Wextra -Wreturn-type -fno-strict-aliasing -D_FILE_OFFSET_BITS=64 -D_LARGE_FILE -I/usr/include/libusb-1.0  -D_FORTIFY_SOURCE=2  -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector-strong -fno-plt -MT RKScan.o -MD -MP -MF .deps/RKScan.Tpo -c -o RKScan.o RKScan.cpp mv -f .deps/RKBoot.Tpo .deps/RKBoot.Po mv -f .deps/RKImage.Tpo .deps/RKImage.Po mv -f .deps/crc.Tpo .deps/crc.Po mv -f .deps/RKComm.Tpo .deps/RKComm.Po mv -f .deps/RKLog.Tpo .deps/RKLog.Po mv -f .deps/RKScan.Tpo .deps/RKScan.Po mv -f .deps/RKDevice.Tpo .deps/RKDevice.Po main.cpp: In function ‘bool _Z9mergeBootv.part.0()’: main.cpp:1541:36: error: ‘%s’ directive output may be truncated writing up to 557 bytes into a region of size 5 [-Werror=format-truncation=] 1541 |  snprintf(buffer, sizeof(buffer), "%s", chip);       |                                    ^~ ...... 1582 |  chipType = convertChipType(chip + 2);       |              ~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /usr/include/stdio.h:867,                 from DefineHeader.h:3,                 from main.cpp:11: /usr/include/bits/stdio2.h:67:35: note: ‘__builtin_snprintf’ output between 1 and 558 bytes into a destination of size 5   67 |  return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,       |          ~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~   68 |        __bos (__s), __fmt, __va_arg_pack ());       |        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cc1plus: all warnings being treated as errors make[1]: *** [Makefile:471: main.o] Error 1 make[1]: Leaving directory '/var/tmp/pamac-build-joshua/rkdeveloptool/src/rkdeveloptool' make: *** [Makefile:491: all-recursive] Error 1 ==> ERROR: A failure occurred in build().
Edit the pkgbuild to change that
(07-07-2020, 02:51 PM)tophneal Wrote: Edit the pkgbuild to change that
Where is that located?
You should be prompted when installing it by pamac. It’ll ask if you want to edit the pkgbuild before attempting to install.
(07-07-2020, 03:02 PM)tophneal Wrote: You should be prompted when installing it by pamac. It’ll ask if you want to edit the pkgbuild before attempting to install.
"--disable-werror" is not in the PKGBUILD but in the diff tab and that does not appear to be editable.
Apparently this is the error in pacmac
This’s is likely what I was trying to say:
https://wiki.archlinux.org/index.php/Mak...e_succeeds
Try adding the suggested option to the pkgbuild. Or you can try grabbing it from git and building it manually
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,239 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,533 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,662 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 2,816 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 32,807 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,223 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,780 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,501 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,886 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,608 09-04-2024, 10:35 AM
