pCloud Client on PBP w/ Manjaro?
Is it possible to install pCloud client on PBP with Manjaro?   I tried the installer and manual installation but neither worked.
Which pcloud are you trying to install? I see the AUR has a pcloud-drive. It appears the official AppImage is x86 only. You may try altering the PKGBUILD for pcloud-drive in the AUR to include the aarch64 architecture. It's not guaranteed to work, but it might.
Thanks! I am on the steep part of the learning curve here. Any advice on a tutorial to learn how to try this would be much appreciated.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,599 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,256 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,368 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,120 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,663 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,013 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,263 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,509 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,475 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,349 11-14-2023, 10:57 AM
Last Post: trifleneurotic
