RStudio for Manjaro?
Has anyone been successful installing RStudio on Manjaro? There is a straightforward installation for OpenSuse xfce, and a way to compile from source for Debian/Ubuntu (and apparently for Redhat).
Google searches indicate that it should be possible with `yay i rstudio-desktop-bin` but this returns the wrong binaries. Further google searches turn up that the app hasn't been updated for Manjaro or Arch for quite a while.
Hi, this was a prompt for me to try it. In pamac I see many rstudio packages, the top two suggested both have the current version number, one is -bin and one is not. All of the others despite having things like "git" and "daily" in their name, had older versions.
I tried building the binary first and it failed with an error about converting the Debian package and that tar was missing the file to upack. So I tried the source version. It has many more dependencies and several of them have a build file that indicate cpu architecture that doesn't include aarch64, so if you try to build them, it will exit telling you that p't ackages isn't for aarch64 architecture.  To build them, you have to edit the build files for any of the packages whose arch line doesn't include aarch64, by adding it. I think in most cases, it's not that it's known not to work, people just haven't documented that it does work on aarch64, so you can add it and try. In pamac, you have the opportunity to make these edits after approving the list of packages to install. All of the dependencies compiled without complaint, and I'd guess I had to add 'aarch64' to 5-6 of them. Compiling rstudio-desktop stopped for me saying:
You need to have Java 8 active when building this package.
Please execute `sudo archlinux-java set java-8-openjdk`
Once I did that, it appeared to work well for awhile until:
BUILD FAILED
/var/tmp/pamac-build/rstudio-desktop/src/rstudio-rstudio-3a09be3/src/gwt/build.xml:112: Java returned: 137
Total time: 39 minutes 11 seconds
make[2]: *** [src/gwt/CMakeFiles/gwt_build.dir/build.make:77: gwt_build] Error 137
make[1]: *** [CMakeFiles/Makefile2:443: src/gwt/CMakeFiles/gwt_build.dir/all] Error 2
make: *** [Makefile:172: all] Error 2
==> ERROR: A failure occurred in package().
Thanks for giving the compilation of RStudio a try. Unfortunately, you made it about as far as I did.
D'ya suppose that I could copy the binary from the working OpenSuse installation, and it would run in Manjaro?
are there any news?
anyone succeeded to install RStudio?
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,413 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,026 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,123 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,008 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,514 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,872 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,107 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,278 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,379 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,228 11-14-2023, 10:57 AM
Last Post: trifleneurotic
