PBP with NVMe installed - Issues booting to SD
Hi all,
I have the PBP booting to eMMC with Manjaro (originally shipped with Debian).  I recently received the NVMe adapter and installed a WD Blue SN550 250GB, WDS250G2B0C.  Booting into Manjaro, it sees the NVMe and I'm able to mount the disk and everything seems to be working fine.
I tried to dd some other distros to the SD card and boot to it, but none seem to boot now except for the original Debian image.  I'm trying to determine if this is a power issue now that I have the NVMe drive (I have not taken the drive out to test, been too lazy to take the laptop apart again).
Has anyone else see this behavior?
Thanks!
edp
Having the NVMe drive installed should not interfere with booting from SD.
What method are you using to write images to your SD cards? If you don't hear/feel the "click" when inserting your SD, use somethin and stiff to help push it in until you feel the click of the card securing.
I've used both the Etcher fork from Pine and also just dd the image to the SD.  The SD card is seating properly.  If I use the Debian Desktop Community build, it boots to the "Open Sesame" screen as expected.  Every other image I've tried, the light on the PBP display orange/amber and then green as expected, but just sits at a black screen.  I'll give it another try this weekend and update the thread.
Thank you,
edp
  NVMe drives not detected mattpenn 18 31,024 12-24-2024, 08:54 PM
  NVMe reukiodo 0 2,963 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,403 11-17-2024, 04:24 AM
Last Post: reukiodo
  Pinebook Pro charging issues tomekdev 1 3,895 01-05-2024, 08:40 PM
Last Post: tomekdev
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,677 04-04-2023, 12:16 PM
Last Post: globaltree
  Touchpad Issues - August 2022 Run SteveCaruso 5 7,910 12-14-2022, 11:00 PM
Last Post: doug
Thumbs Up NVMe adapter, Great addition dachalife 2 5,368 11-28-2022, 12:56 PM
Last Post: dachalife
  PBP booting but stops at flashing power led jonasd 13 14,901 09-26-2022, 12:17 AM
Last Post: jonasd
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 2,959 08-12-2022, 06:41 AM
Last Post: JessicaQ
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 9,170 06-19-2022, 09:47 AM
Last Post: Rosbeefandino
