Hacking the Ill-Fitting NVMe Adapter
Lightbulb
This is a bit silly, but I figured I'd post the results anyway. If you, like me, ended up with an M.2 NVMe adapter with a ribbon cable that doesn't fit, you may or may not want to follow in my footsteps and get it to work anyway.
[Image: m2_hack.jpg]
Since the M.2 adapter card is mostly empty of tracks save for the connectors at the end, you can (I think...) safely drill into part of it in such a way as to allow mounting the card in a position that lets the ribbon cable work. You only get one screw, unfortunately - the other two end up out from under the board - but between that, the ribbon itself, and perhaps some tape or poster putty, it's a fair sight better than letting it hang loose.
I don't know if all the mis-fitted cables are the same, but in my situation, drilling a hole of about 2mm diameter at a point 26mm from the bottom edge and 46mm from the connector-bearing edge (bottom and right edges in the photo attached) turned out to be the ticket. Go slow; if you try to drill through too fast, you'll buckle the copper surface layer outwards on the backside.
I can't test it myself right now - I don't have an M.2 NVMe module of my own, and was mainly just trying to get this thing installed so I could stop worrying about losing it - but I don't see any reason why it wouldn't work.
EDIT: ok, apparently attachments are not a real thing after all. Here's a self-host instead.
  Fitting new case RicTor 1 1,888 05-19-2026, 03:45 AM
Last Post: fnfgopro
  NVMe drives not detected mattpenn 18 31,699 12-24-2024, 08:54 PM
  NVMe reukiodo 0 3,067 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,601 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,826 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,499 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 6,437 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,620 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 5,800 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 5,740 07-22-2021, 05:57 PM
Last Post: calinb
