No Wifi on new pinebook pro
I just received my new pinebook pro today. It booted up no problem. But there is no wifi? When I do ip addr in a terminal it only shows a loopback adapter no wifi adapter.
your help is appreciated.
geekyjm
It appears that some Pinebook Pros are coming from the factory with the privacy switch engaged.
See this;
https://wiki.pine64.org/index.php/Pinebo...y_Switches
Arwen Evenstar
Princess of Rivendale
My new Pinebook Pro also does not seem to be able to use Wifi; I've already tried the privacy switch and it does nothing, except it seems to turn off the bluetooth, which is working apart from the Wifi. Any ideas of why that would be? I was under the impression that both wifi and bluetooth were handled by the same AMPAK chip but perhaps I misunderstand?
Edit: It turns out the issue was largely PEBKAC. The privacy switch indicator and the privacy switch itself seem to be separate toggles; tapping META+F11 causes the privacy switch indicator to blink as if you'd toggled the Wifi without actually toggling it. One needs to hold META+F11 for three seconds before it will actually cause the privacy switch to toggle.
  dead Pinebook - help please RicTor 3 763 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,703 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 7,913 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 667 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,261 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,216 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 3,971 06-28-2025, 01:25 AM
Last Post: Www
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 4,529 03-31-2025, 07:14 AM
Last Post: Anarethos
  Use SD to install new OS over pinebook debian Rudy558 10 25,622 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,047 02-05-2025, 03:56 AM
Last Post: waylonwesley
