How to enable boot logs on PBP
Hello everyone,
I'd like to see the kernel boot messages instead of the splash screen when booting up my pinebook pro. I'm running on the default debian image.
In the wiki there is a section about it (https://wiki.pine64.org/index.php/Pinebo...e_messages) mentioning a u-boot config file at `/etc/default/u-boot/` and an update command (`u-boot-update`).
The problem is my filesystem has neither of those. The next best thing I could find is a config file at `/boot/extlinux/extlinux.conf`, suggesting the use of syslinux instead of u-boot.
Can someone clarify this for me? Is the wiki outdated or something is wrong with my installation?
Deceptive, nothing at all to do with syslinux
Just another, different interface to u-boot,, instead of boot.txt/boot.scr OR boot.cmd/boot.scr/uEnv.txt
So no use looking for the unicorn, a menu.c32 in ARM64, even if you found, wouldn't work
You could try,, copy extlinux to *.orig, edit removing bootsplash
Let us know
The simplest way to see the boot-time messages is change the file /boot/extlinux/extlinux.conf from "console=ttyS2,1500000n8" to "console=tty1". It doesn't log the messages, but at least you can see them.
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,333 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,964 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,450 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,571 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,924 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,593 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,976 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,710 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,749 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,959 01-16-2024, 09:17 AM
Last Post: jbradley419
