Whatever I do, I can not login to my Google Account with Chromium on Pinebook Pro.
"Less secure apps" is on.
Firefox works so far.
Chromium on Pinebook Pro blocked by Google: "This browser or app may not be secure"
"Less secure apps" is on. Firefox works so far.
03-04-2020, 06:21 AM
03-04-2020, 12:19 PM
(03-04-2020, 06:21 AM)jiyong Wrote:(03-01-2020, 02:28 PM)lowry Wrote: Whatever I do, I can not login with chromium on Pinebook Pro. Indeed. I can't login to Google Account with Chromium on Pinebook Pro.
03-05-2020, 03:46 AM
Ok, do you start Chromium from the panel (at the bottom), or through the menu?
Chromium starting from the panel spoofs the user-agent. You can try to alter it to spoof a newer version (right click > properties). Did you try to update Chromium with the package manager? If all else fails, you can try to install a newer version with snap. Jamie Phillips has a video where he explains how to do it. https://www.youtube.com/watch?v=5STcNkylTAg
03-05-2020, 07:01 AM
I had the same happen, but it seemed it happened when I started Chromium before the network connection was established. When I quit Chromium, then reconnect the WiFi and restart Chromium it worked.
| Updated Pinebook Pro? | tantamount | 2 | 2,386 |
06-20-2026, 10:14 AM Last Post: tantamount |
| Pinebook pro bricked? | michaelmoua | 4 | 8,185 |
05-26-2026, 02:20 AM Last Post: Anthona |
Finally got Kali working on my Pinebook Pro! | qingss0 | 0 | 1,838 |
04-04-2026, 08:00 AM Last Post: qingss0 |
| dead Pinebook - help please | RicTor | 3 | 3,467 |
03-26-2026, 04:22 PM Last Post: williamcorlin |
| Pinebook problem | meghancordo | 2 | 6,886 |
03-18-2026, 08:58 AM Last Post: RicTor |
| Pinebook Pro in EU for Sale - €90 | jan_vdk | 5 | 10,807 |
02-09-2026, 12:50 AM Last Post: Anthona |
| Pinebook Pro for sale | rfm83 | 0 | 2,014 |
11-08-2025, 09:22 AM Last Post: rfm83 |
Full desktop Surfing and Absolute Privacy on the pinebook? | Www | 1 | 8,890 |
08-02-2025, 08:55 PM Last Post: KC9UDX |
Printing and scanning documents with pinebook? | Www | 0 | 5,272 |
06-28-2025, 01:25 AM Last Post: Www |
| Use SD to install new OS over pinebook debian | Rudy558 | 10 | 30,044 |
03-09-2025, 11:17 AM Last Post: davisthomas |
