X blank screen
I've changed resolution on pinebook pro debian to 1024x768.
The screen become black.
How can I return resolution 1920x1080 from the CLI?
xrandr -q
xrandr -s [resolution]
Once your resolution is restored, try using the Tweak app to set scaling, instead.
(02-06-2020, 07:15 AM)tophneal Wrote: xrandr -q
Thank you very much!
It' s what I search for.
(One thing to add before this commands:
export DISPLAY=:0.0
Otherwise "Can't open display".)
Perfect. I've added a trouble shooting section for this problem & solution;
Wiki - Pinebook Pro - After changing builtin LCD resolution, blank screen
As usual, feel free to correct, improve or comment, (good or politely bad).
Arwen Evenstar
Princess of Rivendale
(02-07-2020, 10:10 AM)Arwen Wrote: Perfect. I've added a trouble shooting section for this problem & solution;
I tried your solution but message pops up can't open display :0
I don't know what to do then? please help
Sorry, I just copied the other person's solution, (which worked for them), to the Wiki. I've never experienced this problem.
You can try something like this, but I don't make any guarentees;
  • Using a text console, (Control-Alt-F1), login with your normal user ID
  • Edit the file "nano ~/.config/monitors.xml"
  • Change the "width" value to "1920"
  • Change the "height" value to "1080"
  • If there is more than one monitor configuration listed, edit that one too.
  • Be careful to make no other changes. If needed exit without saving and re-edit.
  • Save the file and exit.
  • If you are still loggied in via the GUI, you will have to reboot using "sudo shutdown -r now".
  • After the reboot, you should be able to login to the GUI login and have the resolution back to normal.
Let us know if that worked, so I can update the Wiki.
Arwen Evenstar
you were not talking to me but i had the same problem and did what you suggested and it worked!
(02-18-2020, 05:27 PM)judgeruss Wrote: ...
Great! Glad I was able to help.
I've updated the Wiki to include this addition method to fix the problem;
Arwen Evenstar
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,885 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,691 05-31-2024, 09:42 AM
Last Post: SynthGal
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 3,374 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,588 04-01-2023, 03:22 PM
Last Post: TRS-80
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 2,074 02-16-2023, 10:58 AM
Last Post: cowsay
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 5,501 09-23-2022, 08:37 PM
Last Post: computerc
  How do I change screen brightness in Dietpi computerc 2 5,310 07-15-2022, 07:59 PM
  Adjusting screen resolution lead to a black screen Linux-Rob 28 52,135 06-27-2021, 02:12 AM
Last Post: Arwen
  PacMan Transaction Summary Blank Until Mouse Moves dennisfaucher 0 3,843 06-02-2021, 09:27 AM
Last Post: dennisfaucher
  Manjaro Issues: Dark Screen & Font size Sally2 1 6,671 12-19-2020, 03:33 PM
Last Post: wove
