Manjaro Update Broke QT5
Hey - just looking for a quick bit of advice.
Looks like the recent manajro updates just broke a number of apps I had running smoothly (namely electrum and nextcloud desktop sync).
Possibly others I haven't spotted yet. They fail with
My investigations make me think this is an issue with the pyQT5 / QT5 common conflict - although i can't seem to figure out how I'm supposed to fix this (nothing installed with pip).
I'm new to Manjaro and unsure of how regular these things are and how long they tend to hang around before a fix comes.
So my question is simply is it worth reverting to a previous state or do fixes tend to show up in pacman pretty quick?
this is a known issue, and goes all the way up to the packages from Arch ARM. Easiest solution is to install downgrade and use sudo downgrade package(s) to revert back to previously working versions.
Fixes should be already on mirrors. Try "pacman -Syyuu".
Hey guys thanks for the pointers.
`pacman -Syyuu` - didn't help
Will have a look at downgrade, doesn't appear ot be in pacman so I guess I may have to build that myself.
will hold off on recovering from backup image for a few days and see if I can use this as a learning experience Smile
OK got there!
This thread helps where it also looks like clover had the same problem: https://forum.manjaro.org/t/new-qt5-es2-...g/121892/7
For the sake of clarity and making it quicker for others this was solved by:
1) Install "downgrade" from AUR
2) Run "pacman -Qs qt5-" to get a list of all the packages which are 5.14.1
3) Run "sudo downgrade qt5-..." for each package name
4) select the 5.14.0 version (usually option 1)
5) I've generally excluded from updates for the moment to avoid having to do this tomorrow Smile
Thanks for the pointers !
Out of curiosity whats the best way to follow when these packages are fixed - or would you generally wait for 5.14.2 and give that a try?
Kinda new to tracking packages this closely
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,707 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,422 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,521 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,213 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,186 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,748 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,088 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,424 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,663 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,556 12-07-2023, 03:11 PM
