Crash in brcmfmac joining WPA2 network
Has anyone had trouble with WPA2 wireless networks? I seem to be getting a driver crash after authentication. Wifi works fine on my home network and an unsecured network on the same access points as the failing WPA2 network. This is danielt's Debian Bullseye image, which I believe is using the tsys kernel.
--> log here <--
I am having same problem with my home wireless network which is secured with WPA2. After some time I see in dmesg error related to WiFi module, and the NetworkManager Applet disappeared from the Tool bar. Happened till now two times. Log will be attached later on.
I see the same issue with an up-to-date Manjaro image (wrote 19.12 kde release to an sd card, booted, ran `pacman -Syu`, rebooted). Makes it less likely to be missing firmware, I think?
Any advice troubleshooting this? i'm a developer but have never worked on the kernel.
I don't have any wireless issues on debian sid arm64 with tsys kernel and the same brcm blobs as Manjaro (stolen from them...)
(01-25-2020, 04:09 PM)xmixahlx Wrote: I don't have any wireless issues on debian sid arm64 with tsys kernel and the same brcm blobs as Manjaro (stolen from them...)
Just to confirm, you've been able to connect to and use WPA2 networks?
yes wpa2
I rebuilt the nm-applet from git to add --indicator for sway, tho.... so this isn't a package from unstable
I forgot to write that I am using stock image (Debian+Mate?) with no any modification. Problem occurred two times when watching online streaming video.
(01-27-2020, 01:34 AM)vrabac Wrote: I forgot to write that I am using stock image (Debian+Mate?) with no any modification. Problem occurred two times when watching online streaming video.
and here the dmesg log from crash:
[Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:06 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:42:06 2020] dhdsdio_readframes: too long: len 6176 rdlen 6144 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:42:06 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:06 2020] dhdsdio_rxglom (superframe): len 0x2420, rounded 0x2500, expect 0x1900 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:06 2020] dhdsdio_rxglom (superframe): len 0x0014, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:06 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:42:06 2020] dhdsdio_readframes: too long: len 4640 rdlen 4608 [Tue Jan 21 21:42:06 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:42:35 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:42:35 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:35 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:42:35 2020] dhdsdio_readframes: too long: len 7712 rdlen 7680 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:42:35 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:35 2020] dhdsdio_rxglom (superframe): len 0x1820, rounded 0x1900, expect 0x0d00 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:35 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:42:35 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:42:35 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:43:15 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:43:15 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:43:15 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:15 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:43:15 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:43:15 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 115 [Tue Jan 21 21:43:15 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:15 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 115 [Tue Jan 21 21:43:15 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:43:16 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:43:16 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:43:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:16 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:43:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:43:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 137 [Tue Jan 21 21:43:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:16 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 137 [Tue Jan 21 21:43:16 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:43:46 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:43:46 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:43:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:46 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:43:46 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1300 [Tue Jan 21 21:43:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:46 2020] dhdsdio_rxglom (superframe): len 0x1820, rounded 0x1900, expect 0x1300 [Tue Jan 21 21:43:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:46 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:43:57 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:43:57 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:57 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:43:57 2020] dhdsdio_readframes: too long: len 3104 rdlen 3072 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 8 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:43:57 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 8 [Tue Jan 21 21:43:57 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:44:06 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:44:06 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:44:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:06 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:44:06 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:44:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:06 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:44:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:06 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:44:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:06 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:44:06 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:44:31 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:44:31 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:31 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:44:31 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x1300 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:31 2020] dhdsdio_rxglom (superframe): len 0x1a20, rounded 0x1b00, expect 0x1300 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:31 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:31 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:44:31 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:44:31 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:44:31 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:44:31 2020] dhdsdio_readframes: too long: len 3136 rdlen 3104 [Tue Jan 21 21:44:31 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:45:26 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:45:26 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:26 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:45:26 2020] dhdsdio_readframes: too long: len 12320 rdlen 12288 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:45:26 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:26 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:26 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:45:56 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:45:56 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1300 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): len 0x1820, rounded 0x1900, expect 0x1300 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 139 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 139 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:45:56 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:45:56 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): len 0x0014, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): len 0x1980, rounded 0x1a00, expect 0x0d00 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:45:56 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:45:56 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:46:06 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:46:06 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:46:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:06 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:46:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom (superframe): len 0x2420, rounded 0x2500, expect 0x1900 [Tue Jan 21 21:46:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 63 [Tue Jan 21 21:46:06 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:06 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 63 [Tue Jan 21 21:46:06 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:46:25 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:46:25 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:46:25 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:25 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:46:25 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:46:25 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:25 2020] dhdsdio_rxglom (superframe): len 0x1820, rounded 0x1900, expect 0x0d00 [Tue Jan 21 21:46:25 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:25 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:25 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:25 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:25 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:46:26 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:46:26 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:46:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:26 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1f00 [Tue Jan 21 21:46:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom (superframe): len 0x22e0, rounded 0x2300, expect 0x1f00 [Tue Jan 21 21:46:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 28 [Tue Jan 21 21:46:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:46:26 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 28 [Tue Jan 21 21:46:26 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:16 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:16 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:16 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0400 [Tue Jan 21 21:47:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom (superframe): len 0x0480, rounded 0x0500, expect 0x0400 [Tue Jan 21 21:47:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 38 [Tue Jan 21 21:47:16 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:16 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 38 [Tue Jan 21 21:47:16 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:26 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:26 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:26 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:47:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:47:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 106 [Tue Jan 21 21:47:26 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:26 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 106 [Tue Jan 21 21:47:26 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:36 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:36 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:36 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:36 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x2500 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:36 2020] dhdsdio_rxglom (superframe): len 0x2b60, rounded 0x2c00, expect 0x2500 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:36 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:36 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:36 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:36 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:36 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:36 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:46 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:46 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 131 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 132 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:46 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:46 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:46 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:46 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:47:55 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:47:55 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:47:55 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:55 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1900 [Tue Jan 21 21:47:55 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom (superframe): len 0x1e20, rounded 0x1f00, expect 0x1900 [Tue Jan 21 21:47:55 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 57 [Tue Jan 21 21:47:55 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:47:55 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 57 [Tue Jan 21 21:47:55 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:48:14 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:48:14 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:48:14 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:14 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:48:14 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:48:14 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 98 [Tue Jan 21 21:48:14 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:48:14 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 98 [Tue Jan 21 21:48:14 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:48:32 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:48:32 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:48:32 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:32 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:48:32 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:48:32 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:32 2020] dhdsdio_rxglom (superframe): len 0x1380, rounded 0x1400, expect 0x0d00 [Tue Jan 21 21:48:32 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:32 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:48:32 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:48:32 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:48:32 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:48:33 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0c05e4460, addr=0x08000, pkt_len=224, ERR=-84 [Tue Jan 21 21:48:33 2020] dhdsdio_readframes: read 224 data bytes failed: -35 [Tue Jan 21 21:48:33 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:48:33 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:48:51 2020] ETHER_TYPE_802_1X[wlan0] [RX]: ver 2, type 3, replay 7 [Tue Jan 21 21:48:52 2020] ETHER_TYPE_802_1X[wlan0] [TX]: ver 1, type 3, replay 7 [Tue Jan 21 21:49:24 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc092c89c60, addr=0x08000, pkt_len=512, ERR=-84 [Tue Jan 21 21:49:24 2020] dhdsdio_readframes: read 512 data bytes failed: -35 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:49:24 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:49:24 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:49:24 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:24 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom (superframe): len 0x1380, rounded 0x1400, expect 0x0d00 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 123 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:24 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 123 [Tue Jan 21 21:49:24 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:49:25 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc092c8b060, addr=0x08000, pkt_len=512, ERR=-84 [Tue Jan 21 21:49:25 2020] dhdsdio_readframes: read 512 data bytes failed: -35 [Tue Jan 21 21:49:25 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:49:25 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:49:29 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:49:29 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:29 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:49:29 2020] dhdsdio_readframes: too long: len 8224 rdlen 8192 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: terminate frame [Tue Jan 21 21:49:29 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:29 2020] dhdsdio_rxglom (superframe): len 0x13a0, rounded 0x1400, expect 0x0d00 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:29 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:29 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:29 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:49:44 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:49:44 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:49:44 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:45 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom (superframe): len 0x0012, rounded 0x0100, expect 0x1f00 [Tue Jan 21 21:49:45 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom (superframe): len 0x2a20, rounded 0x2b00, expect 0x1f00 [Tue Jan 21 21:49:45 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 49 [Tue Jan 21 21:49:45 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:49:45 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 49 [Tue Jan 21 21:49:45 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:53:43 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:53:43 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:53:43 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:53:43 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:53:43 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:53:43 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 39 [Tue Jan 21 21:53:43 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:53:43 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 39 [Tue Jan 21 21:53:43 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:54:18 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:54:18 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:54:18 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:18 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x1300 [Tue Jan 21 21:54:18 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom (superframe): len 0x1820, rounded 0x1900, expect 0x1300 [Tue Jan 21 21:54:18 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 60 [Tue Jan 21 21:54:18 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:54:18 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 60 [Tue Jan 21 21:54:18 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:54:24 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:54:24 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:54:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:24 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:54:24 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0f00 [Tue Jan 21 21:54:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:24 2020] dhdsdio_rxglom (superframe): len 0x10a0, rounded 0x1100, expect 0x0f00 [Tue Jan 21 21:54:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:24 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:54:24 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:54:24 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:54:24 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:57:27 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:57:27 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:57:27 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:27 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:57:27 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:57:27 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:27 2020] dhdsdio_rxglom (superframe): len 0x1220, rounded 0x1300, expect 0x0d00 [Tue Jan 21 21:57:27 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:27 2020] dhdsdio_rxglom (superframe): len 0x0030, rounded 0x0100, expect 0x0d00 [Tue Jan 21 21:57:27 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:27 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:57:27 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:57:29 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f101a220, addr=0x08000, pkt_len=32, ERR=-84 [Tue Jan 21 21:57:29 2020] dhdsdio_readframes: RXHEADER FAILED: -35 [Tue Jan 21 21:57:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:29 2020] dwmmc_rockchip fe310000.dwmmc: All phases work, using default phase 0. [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom (superframe): len 0x0010, rounded 0x0100, expect 0x2500 [Tue Jan 21 21:57:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom (superframe): len 0x2a00, rounded 0x2a00, expect 0x2500 [Tue Jan 21 21:57:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 141 [Tue Jan 21 21:57:29 2020] dhdsdio_rxfail: abort command, terminate frame, send NAK [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom (superframe): HW hdr error: len/check 0x0000/0x0000 [Tue Jan 21 21:57:29 2020] dhdsdio_rxglom: got unlikely tx max 0 with tx_seq 141 [Tue Jan 21 21:57:29 2020] dhdsdio_rxfail: abort command, terminate frame [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] dhd_bus_rxctl: FAILEDstatusREAD, LINE 2957 [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] bcmsdh_sdmmc: Failed to Read word F1:@0x0c020=ffffffff, Err: 0xffffff92 [Tue Jan 21 21:57:31 2020] bcmsdh_reg_read: error reading addr 0xc020 size 4 [Tue Jan 21 21:57:31 2020] dhd_bus_rxctl: FAILEDstatusREAD, LINE 2986 [Tue Jan 21 21:57:31 2020] dhd_bus_rxctl: resumed on timeout, INT status=0x00000000 [Tue Jan 21 21:57:31 2020] sdioh_buffer_tofrom_bus: RX FAILED ffffffc0f14f4000, addr=0x0fffc, pkt_len=4, ERR=-110 [Tue Jan 21 21:57:31 2020] dhdsdio_membytes: membytes transfer failed [Tue Jan 21 21:57:31 2020] Dump dongle memory [Tue Jan 21 21:57:31 2020] dhd_schedule_memdump: buf(va)=ffffffc07d700000, buf(pa)=7d700000, bufsize=819200 [Tue Jan 21 21:57:31 2020] dhd_bus_rxctl: rxcnt_timeout=1, rxlen=0 [Tue Jan 21 21:57:31 2020] Dump dongle memory [Tue Jan 21 21:57:31 2020] open file /installmedia/mem_dump_ERROR_RX_TIMED_OUT_1579643852.340935, try /data/ [Tue Jan 21 21:57:31 2020] write_dump_to_file: file_path = /data/mem_dump_ERROR_RX_TIMED_OUT_1579643852.340935 [Tue Jan 21 21:57:31 2020] open file error, err = -2 [Tue Jan 21 21:57:31 2020] dhd_mem_dump: writing SoC_RAM dump to the file failed [Tue Jan 21 21:57:31 2020] dhd_schedule_memdump: buf(va)=ffffffc07d700000, buf(pa)=7d700000, bufsize=819200 [Tue Jan 21 21:57:31 2020] dhd_check_hang: Event HANG send up due to  re=1 te=0 e=-110 s=2 [Tue Jan 21 21:57:31 2020] dhd_os_send_hang_message: Event HANG send up due to  re=1 te=0 s=2 [Tue Jan 21 21:57:31 2020] dhd_check_hang: Event HANG send up due to  re=1 te=0 e=-110 s=2 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_get_station : Could not get WLC_GET_PKTCNTS (-110) [Tue Jan 21 21:57:31 2020] open file /installmedia/mem_dump_ERROR_RX_TIMED_OUT_1579643852.533502, try /data/ [Tue Jan 21 21:57:31 2020] write_dump_to_file: file_path = /data/mem_dump_ERROR_RX_TIMED_OUT_1579643852.533502 [Tue Jan 21 21:57:31 2020] open file error, err = -2 [Tue Jan 21 21:57:31 2020] dhd_mem_dump: writing SoC_RAM dump to the file failed [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3 [Tue Jan 21 21:57:31 2020] dhd_dbg_stop_pkt_monitor, 1963 [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_disconnect : error (-1) [Tue Jan 21 21:57:31 2020] dhd_stop: Enter ffffffc0f1064000 [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_clear_security : wsec clear failed [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_clear_security : auth clear failed [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_clear_security : wpa_auth clear failed [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_bss_isup : 'cfg bss -C 0' failed: -1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_bss_isup : NOTE: this ioctl error is normal when the BSS has not been created yet. [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_notifier_change_state : wlan0:error (-1) [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_update_power_mode : wl_cfg80211_update_power_mode:error (-1) [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : unable to set WL_P2P_DISC_ST_SCAN [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFGP2P-ERROR) wl_cfgp2p_set_discovery : p2p_disc 0 error -1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfgp2p_down : Clean up the p2p discovery IF [Tue Jan 21 21:57:31 2020] wl_cfgp2p_del_p2p_disc_if: wdev: ffffffc0ec9a7c00, wdev->net:           (null) [Tue Jan 21 21:57:31 2020] CFGP2P-ERROR) wl_cfgp2p_disable_discovery :  do nothing, not initialized [Tue Jan 21 21:57:31 2020] Exit. P2P interface stopped [Tue Jan 21 21:57:31 2020] P2P interface unregistered [Tue Jan 21 21:57:31 2020] CFGP2P-ERROR) wl_cfgp2p_deinit_priv : In [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_dongle_down : WLC_DOWN error (-1) [Tue Jan 21 21:57:31 2020] dhd_tcpack_suppress_set: TCP ACK Suppress mode 1 -> mode 0 [Tue Jan 21 21:57:31 2020] wl_android_wifi_off in 1 [Tue Jan 21 21:57:31 2020] wl_android_wifi_off in 2: g_wifi_on=1, on_failure=1 [Tue Jan 21 21:57:31 2020] dhd_prot_ioctl : bus is down. we have nothing to do - bs: 2, has: 1 [Tue Jan 21 21:57:31 2020] dhd_dbg_detach_pkt_monitor, 2204 [Tue Jan 21 21:57:31 2020] dhd_bus_devreset: == Power OFF == [Tue Jan 21 21:57:31 2020] dhd_txglom_enable: enable 0 [Tue Jan 21 21:57:31 2020] dhd_conf_set_txglom_params: txglom_mode=copy [Tue Jan 21 21:57:31 2020] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0 [Tue Jan 21 21:57:31 2020] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1 [Tue Jan 21 21:57:31 2020] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300 [Tue Jan 21 21:57:31 2020] dhd_bus_devreset:  WLAN OFF DONE [Tue Jan 21 21:57:31 2020] wifi_platform_set_power = 0 [Tue Jan 21 21:57:31 2020] ======== PULL WL_REG_ON(-1) LOW! ======== [Tue Jan 21 21:57:31 2020] [WLAN_RFKILL]: rockchip_wifi_power: 0 [Tue Jan 21 21:57:31 2020] [WLAN_RFKILL]: wifi shut off power. [Tue Jan 21 21:57:31 2020] wl_android_wifi_off out [Tue Jan 21 21:57:31 2020] wl_ext_iapsta_dettach_netdev: ifidx=0 [Tue Jan 21 21:57:31 2020] dhd_stop: Exit [Tue Jan 21 21:57:31 2020] CFG80211-ERROR) wl_cfg80211_hang : In : chip crash eventing, reason=0x8001
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,362 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro network problem late 2023 acruhl 1 4,007 01-19-2024, 11:32 PM
  More heavy network traffic leads to network break-down ericzolf 3 4,784 09-30-2023, 08:06 AM
Last Post: ericzolf
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 3,420 08-18-2023, 02:06 AM
Last Post: juliamenendez
  Pinebook Pro w/ Manjaro KDE Random Freeze/Crash BenniTec 1 5,061 03-18-2022, 04:03 PM
Last Post: BenniTec
  Network shared folder discovery (smb4k) solostian 10 21,043 12-06-2021, 07:27 AM
Last Post: solostian
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 4,137 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
  Kernel crash on Manjaro ARM mfashby 0 4,239 07-06-2021, 03:17 PM
Last Post: mfashby
Bug Manjaro - KDE/Plasma - Random Crash Anarethos 1 5,884 01-26-2021, 01:44 PM
Last Post: FFabian
  Network settings, where to find the config files? hvdkooij 1 5,668 11-20-2020, 02:47 PM
Last Post: xyzzy
