Flashing image to EMMC
(01-17-2020, 07:12 AM)f1refl1r Wrote: I am still figuring things out and I want to re-install the original OS on my Pinebook Pro. I managed to get the Debian on a SD card and are able to boot the PBP from teh SD card. How do I run the installer script now?
Sad
Cheers
This is my bad, sorry. I thought I recalled seeing danielt mention the script could be modified to install the default Debian. Upon further review of the thread, I think I was wrong. The easiest way will probably be for you to just download the Debain image in that install, and then dd it to your emmc.
Sad
Cheers
no worries, and sorry to bother you with this. I am unfamiliar with dd. I have identified the internal emmc with gparted. I downloaded the OS again while booted from the SD, I have extracted the img file to the dowload folder. Am I correct in using the following? Or do I have to point to the download folder and then point at the image?
sudo dd if=my_OS_image.img of=/dev/my_emmc_location bs=4M status=progress
No worries, better to ask questions when you don't know the answers.
Yup! Fill in those blanks, and you'll be on your way to Debian back on your emmc.
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 2,978 01-03-2026, 07:09 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,429 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 2,750 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 4,918 10-23-2025, 09:38 AM
Last Post: jceaser
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,991 01-16-2024, 09:17 AM
Last Post: jbradley419
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 106,762 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 6,795 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 5,570 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro won't turn on after flashing image Idaho 2 4,316 02-21-2023, 02:31 PM
Last Post: Idaho
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,893 02-21-2023, 01:49 AM
Last Post: repa
