Bionic image boot from SD
I flashed Bionic onto the eMMC and now SD boot is no longer working.  I think the uboot is the issue, but I do not know how to go about fixing it.  Ideas?
(01-16-2020, 02:45 AM)mamboman777 Wrote: I flashed Bionic onto the eMMC and now SD boot is no longer working.  I think the uboot is the issue, but I do not know how to go about fixing it.  Ideas?
Hey assuming you're folowing this guide: https://forum.pine64.org/showthread.php?tid=8119
Sounds like you needed step 6..
6. Now you have Ubuntu installed on eMMC and you can also boot from SD card, but only the same operating system. If we need also to boot other operating systems, we need to apply uboot fix. So download all the files from here https://github.com/mrfixit2001/updates_r...filesystem and run the mrfixit_update.sh script while running from eMMC. From now on you should be able to boot also other OS from SD like before.
Download those files and run the script and then it starts working.e
I did try that, but not from the director /usr/bin  I remember reading somewhere that I need to run it from /usr/bin, so I'll give that a shot and let you know.
Ok....I must be doing something wrong with the mr fixit update. I had the same result. any other ideas to try?
You shouldn't have to run that script from any particular location. You only need to download it to your drive, along with the 3 u-boot .img files in that repo folder, to the same folder. Then, go to that folder in terminal/tty, and run the script.
It looks like the script is running. I'm getting:
Identified /dev/mmcblk1 as device to flash uboot to...
upgrading idbloader.img...
upgrading uboot.img...
upgrading trust.img...
That being said for some reason it looks like I have 5 partitions before the boot partition on my eMMC. Maybe I should try deleting those partitions?
I'm afraid to brick it since I can't boot from the SD. I've got an eMMC -> USB adapter in the mail. If I completely remove the eMMC would the SD boot function again?
Does it go back to normal prompt after "upgrading trust.img..."? If so, you should now be able to reboot into an SD. I had similar issues/confusion when I first used a modified version of that script to run on Chromium. It wouldn't indicate it finished with success, but it did.
I do not know what I did differently this time, but it seems to have worked! Thanks for your help! :-)
Awesome! Now go boot those SDs! ;P
(01-16-2020, 08:25 AM)tophneal Wrote: Awesome! Now go boot those SDs! ;P
Now I'm waiting on my Intel 660p NVMe to arrive.  When it comes in I'll be trying to put /root/ on the NVME, but it's good to know that I now have a back up plan if things do not go as planned.  :-)
Nice Wink Glad it's working again!
  I think you can try compiling the PC version image of OpenHarmonyOS 5 or 5.1 wangyukunshan 2 1,007 01-03-2026, 07:09 AM
Last Post: qingss0
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 562 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 1,013 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 22,890 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 14,639 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 10,740 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 3,566 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 4,642 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 3,147 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 7,198 01-19-2024, 02:29 PM
