U-Boot with direct NVMe boot support for eMMC/SPI Flash
#41
(01-13-2020, 05:13 AM)mamboman777 Wrote: I do not understand how to get this working. I used gnome-disk-utility to"restore" a fresh disk image to s micro SD card. I booted to the SD card then "restored" Manjaro to the emmc and default Debian to the nvme. According to the wiki the uboot code that I need is in the Manjaro release, but it's still booting from SD card first, emmc second. Nothing from nvme. What am I doing wrong?
I think that NVMe is just third in the order. So I needed to remove OS from eMMC to boot from NVMe.
I tried completely wiping the emmc and got nothing. Is something supposed to be on the emmc that points to the nvme? Or did I miss flashing something onto the board that points to the nvme?
So it seems that you did not flash it correctly or completely, not sure. I flashed it directly from rkdeveloptool.
(01-13-2020, 06:19 AM)Wizzard Wrote: So it seems that you did not flash it correctly or completely, not sure. I flashed it directly from rkdeveloptool.
That's what I'm missing. I'm sorry for my ignorance.  What needs to be flashed?
Well, I got something to happen...I followed the instructions for flashing. The machine powered on once too the open sesame screen, them rebooted and nothing. Worse yet, now when an SD is inserted it powers on, the led flashes and the machine appears to power off. Appears I've gone and created a paperweight. Any ideas how to get this working?
I followed this guide https://iotbyhvm.ooo/rockpi-4-write-imag...-otg-port/ from chapter "Write to SPI flash via USB" and flashed this file: https://github.com/pcm720/rockchip-u-boo...iflash.bin
Can't even boot onto anything now. I'm too frustrated she need to step away till this evening. I'll check back later.
No problem, to boot PBP in the MASKROM mode, use Recovery button and connect it to your PC with USB-C cable.
(Need to open PBP and uncover the PCB) The button is no. 28.
[Image: PBPL_S.jpg]
(01-13-2020, 07:03 AM)Wizzard Wrote: No problem, to boot PBP in the MASKROM mode, use Recovery button and connect it to your PC with USB-C cable.
[Image: PBPL_S.jpg]
Thank you.  That all makes sense. I will be able to do this when I get home from work tonight.  After I connect it to pic, then what?
I dont remember everything what I did but I see that it is necessary to download rkdeveloptool in Linux and build it.
git clone https://github.com/rockchip-linux/rkdeveloptool
cd rkdeveloptool
autoreconf -i
./configure
make
and then to flash that spi image.
rkdeveloptool wl 0 /path/to/uboot-trust-spi.img
(01-13-2020, 08:05 AM)Wizzard Wrote: I dont remember everything what I did but I see that it is necessary to download rkdeveloptool in Linux and build it.
cd rkdeveloptool
autoreconf -i
./configure
make
Thank you so much for taking the time to do this.  What does "wl 0" do? I am able to follow terminal commands and will do this when I get home, but I also would like to try to understand what I'm doing. Is the spi the bit of code that is on board itself?
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 1,641 12-18-2025, 01:05 AM
Last Post: qingss0
  swap eMMC advice jceaser 2 1,913 10-23-2025, 09:59 PM
  Need new eMMC Karsten1 2 3,985 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 2,142 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 29,358 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 18,297 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,082 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,174 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,425 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,095 09-04-2024, 10:35 AM
