PineTime case
I got my PineTime dev kit this morning.  Very nice packaging.  When I unpacked everything I found that the case back had come off the watch.  I have been trying to get get the two parts of the watch together so I can charge it for over 30 minutes with no luck.  It looks like the case back should just snap onto the watch but no matter how hard I press this does not happen.  I have the back properly positioned, with the charging pins over the metal connectors on the circuit board.  Is there a trick to getting the case back onto the watch?
No trick involved, the case is usually glued/sealed shut. On the devkit there is no glue, so I usually just use some tape strips to hold it together while charging...
Thank you. I guess it will take me a while to get into maker mode.
Hey, I've received my sample, and I've been pretty disappointed too not be able to properly close the watch body case. Of course I've used some tape strip, but a small screw would have been nice instead. I'm rather impressed with the usability of the dev kit but I think it's important to be able to power it without any trick. As soon as I get a 3D printer, I'll look at printing some additional clips.
Having said that, congratulations guys. The hardware is promising !
Hello, can you send me images about how to close the watch body case?
I don't imagine how to.
(01-28-2020, 04:16 PM)lodopidolo Wrote: Hello, can you send me images about how to close the watch body case?
As far as I know the case on the for-developers-only kit needs to be glued shut to close the watch case. However I'm not sure the software for PineTime is complete enough for that at this stage.
It's the developer version, so it's not meant to. However, the only significant different I know of is that it is simply not glued shut. So if you want to close it up, there is nothing to stop you putting a couple of drops of super glue on it to join it up again. However, not sure how you'd program it afterwards! Big Grin
Easy - drill a hole from the side of the back, pull 4 wires through,solder them in and then glue the back. That's what I did. If you have nicely colored wires, it may even look good! Big Grin
(01-29-2020, 09:56 AM)dejvino Wrote: Easy - drill a hole from the side of the back, pull 4 wires through,solder them in and then glue the back. That's what I did. If you have nicely colored wires, it may even look good! Big Grin
Good idea!!!. Can you attach some images, please?
There are a lot of images in the Development Discussion forum in thread How to get started? Share you development setup.
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 4,764 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 4,842 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,166 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,141 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,063 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,234 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 6,962 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,269 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,160 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,818 01-31-2024, 11:57 AM
Last Post: tynstar
