#91
(12-05-2019, 11:52 AM)josmo Wrote:
(12-04-2019, 05:01 AM)PakoSt Wrote: Thanks to @"Feakster"  (I hope it's the same user Smile ) for pointing out that USB-C video out is working now on the Manjaro forum!
So, from the basics I'm only missing separate headphone and speakers output now Smile
i just get a mirror image no extended monitor
Have you tried Fn + F3?
#92
The issue is observable only with fbturbo - it treats all displays as the default one. If you disable it and run just Panfrost, everything is picked up as expected.
There are a few threads for Raspberry Pi that make adjustment directly to `/etc/X11/xorg.conf.d/99-fbturbo.conf` to manually set the monitor setup. My attempts to use a few of those instructions didn't produce satisfactory results.
On ayufan's and mrfixit's builds I can't see such shenanigans with fbturbo.conf. There should be something else for fbturbo to behave normally with multi-monitor setup that I'm missing.
#93
(12-04-2019, 05:01 AM)PakoSt Wrote: So, from the basics I'm only missing separate headphone and speakers output now Smile
Circumvention Hack: works if you use USB-Audio (e.g.: those USB-to-3mm-jack dongles that come pre-packaged with some headphones)
#94
I don't have one of these available atm. But maybe I will grab one with USB-A to 3.5mm => I could use it later for the PC tower that has bad motherboard 3.5mm out Smile
#95
Hello Wim,
@wvdschel
As your PM is disabled. Here is the answer.
Thank you for taking interest in Manjaro Arm.
Ko-Fi does not take a cut at all and is designed for one-off donations:
https://help.ko-fi.com/hc/en-us/articles...yments-FAQ
So Please use Ko-Fi for your one-time donation.
Cheers.
Thanks.
Manjaro ARM Team.
#96
I run Manjaro xfce off a micro SD card (I started with Preview 3 and keep the packages up to date). I decided to keep Manjaro as my secondary OS as the kernel is rock-stable and userland is 64bit. I started to set it up and feel I'm in the dark Linux ages, again:
- I don't find a GUI setting to turn off the screen after some idle time. All GUI settings just turn the screen black, but not off. Currently, I use xset to manually turn off the screen, e.g.
$ xset dpms force off
- When I ssh -Y into another machine and start emacs remotely, no single font is found. I then installed the 75dpi and 100dpi fonts and needed to manually set +fp /usr/share/fonts/75dpi/ and set +fp /usr/share/fonts/100dpi/. I can't remember the last time I needed to deal with fonts. Shouldn't the fp paths be set automatically by the package manager?
- Manjaro is a rolling release distribution. Some software seems to roll faster than other:
$ /usr/bin/xfce4-screensaver
/usr/bin/xfce4-screensaver: error while loading shared libraries: libxfconf-0.so.2: cannot open shared object file: No such file or directory
The more recent version libxfconf-0.so.3 version is installed. Both seem to be compatible and a soft link fixes the problem
# ln -s /usr/lib/libxfconf-0.so.3.0.0 /usr/lib/libxfconf-0.so.2
- Similar problem with tumblerd (log from systemd journal). Why aren't dependencies automatically installed?
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-ffmpeg-thumbnailer.so": libffmpegthumbnailer.so.4: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro dbus-daemon[971]: [session uid=1000 pid=971] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-poppler-thumbnailer.so": libpoppler-glib.so.8: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro org.freedesktop.thumbnails.Thumbnailer1[971]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-raw-thumbnailer.so": libopenrawgnome.so.7: cannot open shared object file: No such file or directory
Dec 07 18:26:04 manjaro tumblerd[1802635]: Failed to load plugin "tumbler-odf-thumbnailer.so": libgsf-1.so.114: cannot open shared object file: No such file or directory
- gcin always crashes when clicking on its panel icon
Dec 07 23:30:20 manjaro systemd-coredump[1823724]: Process 1822296 (gcin) of user 1000 dumped core.
Stack trace of thread 1822296:
#0 0x0000aaaaccbf8914 n/a (gcin + 0x10914)
#1 0x0000ffffa5c7bff8 g_closure_invoke (libgobject-2.0.so.0 + 0x15ff8)
#2 0x0000ffffa5c93a00 n/a (libgobject-2.0.so.0 + 0x2da00)
#3 0x0000ffffa5c9ce28 g_signal_emit_valist (libgobject-2.0.so.0 + 0x36e28)
#4 0x0000ffffa5c9d430 g_signal_emit (libgobject-2.0.so.0 + 0x37430)
#5 0x0000ffffa60133e4 n/a (libgtk-x11-2.0.so.0 + 0x1e33e4)
#6 0x0000ffffa60133e4 n/a (libgtk-x11-2.0.so.0 + 0x1e33e4)
#7 0x0000ffffa5f88bfc n/a (libgtk-x11-2.0.so.0 + 0x158bfc)
#8 0x0000ffffa5c7bff8 g_closure_invoke (libgobject-2.0.so.0 + 0x15ff8)
#9 0x0000fffff4913d58 n/a (n/a + 0x0)
- Firefox: Add-Ons: Plugins: "OpenH264 Video Codec provided by Cisco Systems, Inc. will be installed shortly." Shorty? I have an uptime of several days. Anyone not having this problem?
#97
(12-07-2019, 06:41 AM)spikerguy Wrote: Hello Wim,
@wvdschel
Cheers.
Thanks.
Doh. I only noticed this message after I've made a donation using the Open Collective yesterday Sad
Are PMs off by default? I've never changed any setting, and can't seem to find it in the profile settings pages either at first glance.
#98
@wvdschel
Cheers.
Thanks.
It is ok to use Open Collective also. Thank you for your generous support.
Even I am not familiar with this forum settings. Please check in your profile.
Cheers.
Manjaro ARM Team.
#99
(12-07-2019, 08:38 PM)Der Geist der Maschine Wrote: I run Manjaro xfce off a micro SD card (I started with Preview 3 and keep the packages up to date). I decided to keep Manjaro as my secondary OS as the kernel is rock-stable and userland is 64bit. I started to set it up and feel I'm in the dark Linux ages, again:
This is the kind of thing I believe to be SoP for ArchLinux and derivatives. I'm open to gentle correction, if I'm mistaken or out of date. Such manual configuration is what led Jamie Zawinski to quip, "Linux is free, only if your time is worthless", about 20 years ago. Relevant to this comment, Jamie is the originator and maintainer of the Xscreensaver collection!
Those years were excellent for learning *Nix systems, 'under the covers' in the day. I feel blessed by the advent of Debian and derivatives with package dependency management, /etc/alternatives, and protection for configuration file customization by the package manager.
— Jeremiah
— Jeremiah Cornelius
I have problems using the camera and microphone with Firefox on a Manjaro KDE that was kept up-to-date with `pacman -Syu`all the way since preview2.
The camera itself works (I can use it with e.g. `ffplay /dev/video3` or 'guvcview-qt -d /dev/video3`)
But it I use Firefox (e.g.: with http://meet.jit.si/ ), I only get 'Default Video Device' in the drop down list, with no other option.
I suspect Firefox is then trying to open the wrong device (`/dev/video0` - the rockchip-rga raster graphics accelerator), because I can't get any picture.
Also the video button stay muted and can't be unmuted.
I get the same problem with audio too, only 'Default Audio Device' too, and weirdly Firefox doesn't show up in the 'Recording' tab of Pulseaudio.
Mike button stays muted too.
Has somebody seen this ?
  Boot Order in Pinebook Pro food 12 16,058 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,010 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,550 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,950 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,442 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,458 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,697 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 114,603 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,251 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,390 03-31-2024, 10:11 AM
Last Post: u974615
