#71
(11-20-2019, 08:15 AM)PRStoetzer Wrote: but the window movement was smoother than on my much more powerful laptops. Very impressive!
Depending on your other systems, that might be due to the fixes that came with the current version 3.34 of Gnome Shell that Manjaro offers.
(11-20-2019, 08:15 AM)PRStoetzer Wrote: The three main problems I have with Manjaro ARM right now are getting hardware acceleration to work in Chromium so that 1080P videos are playable on YouTube, the lack of 5 GHz WiFi, and the lack of suspend.
The default Debian installation comes with the h264ify plugin installed, did you try that?
https://chrome.google.com/webstore/detai...kgioiakgal
#72
Music
Manjaro Preview 4 is out now:
https://forum.manjaro.org/t/manjaro-arm-...pro/112647
Changes listed as:
  • Fully working bluetooth
  • Fixed Wifi instability
  • Enable booting from NVMe - as in... placing the /boot partition on the eMMC/SD and the ROOT partition on the NVMe.
#73
Tried that today, wifi seems to be fixed.
Just redshift (still) does not seem to work and neither Retroarch does not run at full speed (tried Sega Genesis and PSX games). Using KDE.
#74
(11-25-2019, 06:07 AM)Wizzard Wrote: Tried that today, wifi seems to be fixed.
Night Light works well in Wayland sessions, for anyone wondering about the alternative.
Is Redshift still being held back by geoclue? I recall Redshift working on the PB1080 whenever you triggered it, or set the location manually. When attempting automatic, geoclue just never found itself.
#75
Any news on the hardware aceleration for the gpu?
#76
(11-25-2019, 07:14 AM)tophneal Wrote: Night Light works well in Wayland sessions, for anyone wondering about the alternative.
Tried Plasma Wayland session, but Night Light does not work and it is whole very slow, not usable for me.
#77
Bummer! Works very well under Gnome.
#78
Booted up nicely! I had some pops while changing volume.
Also intermittent high frequency noise coming from left speaker.
Wifi not a single problem for me.
edit: I'm a bit slow. this was manjaro kde plasma preview2
#79
How can I safety upgrade from P3 to P4?
Is there any way to be able to see my 5ghz WiFi networks?
Sent from my PH-1 using Tapatalk
#80
(11-25-2019, 02:38 PM)cristobalhdez Wrote: How can I safety upgrade from P3 to P4?
You can use the Add/Remove Software app, or terminal. In the app, open it, click on the Updates tab at the top, and the Apply button in the lower right corner. In terminal, use 'sudo pacman -Syu' (don't use the quotes.) Reboot after your updates are finished.
  Window Maker Live for Pinebook Pro vajak 8 2,312 01-22-2026, 08:00 PM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,619 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,928 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 12,164 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,405 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,973 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,246 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 102,658 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,534 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 9,688 03-31-2024, 10:11 AM
Last Post: u974615
