Network Manager on Deb
Just to ask is there a package for the network manager that adds support for VPN's like L2TP and others like that?
This might be helpful. It looks like Debian has arm builds for the Sid version mentioned in the tutorial.
PPP seems to conflict with it linux being linux it seems
Odd since ppp is a dependency. Does it specify if it needs a different version than what's installed? Maybe it'd be better to attempt building as opposed to installing the deb file.
Correction something out of the 100 commands I tried seem to have installed the addon
*the git code for network-manager-l2tp cannot be built
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,507 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro network problem late 2023 acruhl 1 4,082 01-19-2024, 11:32 PM
  More heavy network traffic leads to network break-down ericzolf 3 4,826 09-30-2023, 08:06 AM
Last Post: ericzolf
  Network shared folder discovery (smb4k) solostian 10 21,181 12-06-2021, 07:27 AM
Last Post: solostian
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 4,175 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
  What window manager do you recomend for lowering ram usage? sunjam 9 26,573 12-03-2020, 11:26 AM
Last Post: rimaille
  Network settings, where to find the config files? hvdkooij 1 5,723 11-20-2020, 02:47 PM
Last Post: xyzzy
  pinebook pro manjaro xfce pacman network error thumbsup 1 5,637 07-11-2020, 02:32 PM
Last Post: thumbsup
  Crash in brcmfmac joining WPA2 network rillian 7 18,129 02-03-2020, 12:36 AM
Last Post: vrabac
