#21
Downloaded the img once again and flashed it to an SD card, no screen output either. I have no idea whether it just doesn't boot or it's only the LCD output that's broken. This worked fine on the first image though
#22
(11-11-2019, 03:41 AM)brent.thierens Wrote: Downloaded the img once again and flashed it to an SD card, no screen output either. I have no idea whether it just doesn't boot or it's only the LCD output that's broken. This worked fine on the first image though
No new images have beenb released. Please wait for sometime until the Manjaro Team test the new images before making it public.?
Thank you for your support & patience.
Manjaro ARM Team.
#23
So it's random then? Strange, I have had Manjaro running with the same image then...
I'll just wait, sorry if I sounded too eager Big Grin
#24
(11-11-2019, 02:59 AM)erchache2000 Wrote:
(11-09-2019, 02:20 PM)pawlinski Wrote: A kernel update has appeared. The sound began to work. Volume function keys also. WiFi also seemed to be more stable. Thanks to the guys from Manjaro Smile
I upgrade my system and I don't have sound, functions keys or wifi... ;(
Did you touch something else?
I hope you solved this from the Manjaro Forum support.
Manjaro ARM Team.
#25
Two things I am noticing:
1. chromium seems to ignore the panfrost driver:
libGL error: failed to create dri screen
libGL error: failed to load driver: rockchip
2. My speakers make noice when the SD card is accessed. Brings back memories of rotating rust drives Wink
#26
The headphones doen't work either (3.5mm), USB headphones work fine
#27
Manjaro ARM - Preview2 released.
https://forum.manjaro.org/t/manjaro-arm-...=spikerguy
For those who was having issued with LCD not working on the Preview1. Please try the Preview2.
Thank you.
Manjaro ARM Team.
#28
(11-11-2019, 11:24 AM)spikerguy Wrote: Manjaro ARM - Preview2 released.
Thank you.
LCD is now working for me.  (KDE plasma ) WiFi (brcmf) is not only flakey , though.  it's pretty much bringing the system to a halt.  (constant failure messages in dmesg).  It seems like this problem has been fixed and then shown up  through a number of kernels on many platforms.  Keep up the great work...this is very exciting.  I'll test more with wifi  disconnected.
#29
(11-11-2019, 02:59 AM)erchache2000 Wrote: I upgrade my system and I don't have sound, functions keys or wifi... ;(
for sound, once you have upgrade (pacman -Syu) :
alsamixer
then go to the far right of the mixer and enable (hit 'M') the headphone DACs:
  • Left Headphone Left Mixer DAC
  • Right Headphone Right Mixer DAC
For me, that made the sound work simultaneously on speaker and headphones.
(though no detection of jack and muting speakers)
But the speaker are extremely noisy if there's no sound playing (it seems/sounds that their level is left floating when there's no output)
#30
alsamixer
I solved my problems applying patch and upgrading system.
Nows runs very well, excepting known bugs.
  Boot Order in Pinebook Pro food 12 19,239 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,562 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,263 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,691 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,401 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,501 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,688 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 124,128 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,782 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,505 03-31-2024, 10:11 AM
Last Post: u974615
